Pulling codes out of my b18a1 EF
Old Jan 20, 2009 | 11:46 PM
chwkef's Avatar
Default Pulling codes out of my b18a1 EF
Hey guys, new to the forums
Just got rid of my RX7, and picked up an EF with a B18A1 in it. After driving for a bit, the check engine light comes on. I was told it was a loose injector clip by the previous owner, but I fixed that and it's still coming on.
I'm not new to modded cars, but am new to modded hondas. How do I pull codes out of my beast? I know the ECU has a light in it...
I'm not sure how the whole OBD-0 and OBD-1 thing works either... If someone could offer some insight that would be great.
Thanks,
-Dirk
Old Jan 21, 2009 | 02:07 AM
ef_junky's Avatar
Default Re: Pulling codes out of my b18a1 EF
well most anything 88-91 is odb0 and 92-95 is obd1 but if it still has the code light on the ecu turn your key to the on postion then look at your ecu it will flash you the code then what you do is count the flashes and there will be a couple second pause in between each code and a probably 6 second or so pause when it starts over..... then heres the codes....1
Accord Civic CRV CRX Del Sol Odyssey Prelude
85-98 86-98 97-98 85-91 93-97 95-98 85-98 Oxygen Sensor "A" (Primary)
defective circuit or unplugged / defective sensor
85-89 86-87 n/a 85-87 85-91 n/a n/a Oxygen Sensor "B"
85-98 86-98 97-98 85-91 93-97 95-98 85-98 MAP Sensor (Manifold Absolute Pressure)
90-98 88-98 97-98 88-91 93-97 95-98 85-98 CKP Sensor (Crankshaft Position Sensor)
85-98 * 86-98 97-98 85-91 93-97 96-98 85-98 MAP Sensor (Manifold Absolute Pressure)
mechanical problem / disconnected piping
* exc 94-95
85-98 86-98 97-98 85-91 93-97 95-98 85-98 ECT Sensor (Engine Coolant Temperature)
85-98 86-98 97-98 85-91 93-97 95-98 85-98 TP Sensor (Throttle Position)
85-98 86-98 97-98 85-91 93-97 95-98 85-98 TDC Sensor (Top Dead Center)
9*
85-98** 86-98 97-98 85-91 93-97 95-98 85-98 CYP Sensor (Cylinder)
* not a valid code for any throttle body injection Hondas
** not a valid code for V-6 engines
10
85-98 86-98 97-98 85-91 93-97 95-98 85-98 IAT Sensor (Intake Air Temperature)
12
85-98 86-98 * n/a 85-91 * n/a 95-98 85-98 EGR Lift Sensor (Exhaust Gas Recirculation)
* not a valid code if car is not equipped with an EGR valve (some Civic models are not)
13
85-98 86-98 97-98 85-91 93-97 95-98 85-98 BARO Sensor (Atmospheric Pressure)
14
88-98 88-98 97-98 88-91 93-97 95-98 88-98 IAC Valve (Idle Air Control)
15
90-95 88-95 n/a 88-91 93-95 95 88-95 Ignition Output Signal
missing or defective ignition output signal
16
90-95 88-95 n/a 88-91 93-95 95 88-95 Fuel Injector System
defective circuit or unplugged / defective fuel injector
17
88-98 88-98 97-98 88-91 93-97 95-97 88-98 VSS (Vehicle Speed Sensor)
19
n/a 88-95 n/a 88-91 93-97 n/a n/a Automatic Transmission Lock Up Control Solenoid Valve
defective circuit or unplugged / defective solenoid valve
20
90-98 88-98 97-98 88-91 93-97 95-98 92-98 Electrical Load Detector
Old Jan 21, 2009 | 01:09 PM
chwkef's Avatar
OK i got the codes. Remember this isn't a stock EF, it has a 93 B18A1, so it has different codes...
Code 16- Fuel injector. Likely because I had a loose injector clip that I fixed yesterday
Code 43- Fuel supply/02 sensor. I'll order an 02 sensor and see if that fixes it.
Old Jan 22, 2009 | 02:58 PM
chwkef's Avatar
ok, I got the number off the ECU
37820-PR4-A10
430-239563AR
So I guess it's a PR4 meaning OBD0?
Old Jan 22, 2009 | 03:17 PM
chwkef's Avatar
I should also mention it does have an injector resistor box... which is only OBD1 correct?
Old Jan 22, 2009 | 07:44 PM
ef_junky's Avatar
no i'm pretty sure that obd0 only has it also only has like 20 codes if its a 93 its obd1...... and yes pr4 is obd0.....
Old Jan 22, 2009 | 07:47 PM
90blackcrx's Avatar
Good read
http://www.c-speedracing.com/faq.php
Old Jan 22, 2009 | 10:10 PM
chwkef's Avatar
hmmm good read. ok so I have a one wire 02 sensor. Do all obd0's have one wire 02's and all obd1's have 4 wire 02 sensors?
Thanks for the help guys, much appreciated. I'm not new to cars, but I just bought this thing and it's my first honda. Trying to figure it all out quickly :S haha
Old Jan 23, 2009 | 12:36 AM
chwkef's Avatar
Just thought of something else....
I don't know if my injectors are from an obd0 b18 or an obd1 b18. Because I'm running an injector resistor box, and if the injectors are obd1, they're not getting the voltage they need....
-Dirk
Old Jan 23, 2009 | 01:54 AM
D16SiHatch's Avatar
-Dirk
that would be correct. obd0 use the box, obd1 get rid of it. also there are obd0 and obd1 pr4's. if there is a light on the ecu then its obd0. having the box is only going to tell you the electronics are all obd0 assuming the car has had nothing change. because someone could be using an obd1 ecu and you could still use the obd0 injectors with the res. box.
Old Jan 23, 2009 | 07:31 AM
chwkef's Avatar
There is a light on the ECU. And there is a resistor box. But the motor is a 93. So idk if the previous owner checked what injectors it had, and just assumed it needed a resistor box.
I'll test the impedance on the injectors sometime today
Old Jan 23, 2009 | 11:52 AM
chwkef's Avatar
Injectors are obd0 Resistance is 2.5-2.6 ohms on all 4. Now I'm not sure what to check next
lew003
May 4, 2014 10:34 AM
b16DooD
Jun 30, 2011 07:49 PM
dirttrackracer
Dec 13, 2007 10:52 PM
EF9Si-T
Jun 17, 2004 07:21 PM
