which ignition is better?
Old Aug 6, 2002 | 07:48 PM
91hatchcivic's Avatar
Default which ignition is better?
which is better for my 91 civic si? the jacobs ice pack , or msd 6A ignition??
Old Aug 6, 2002 | 08:23 PM
DJ KrunchyKracker's Avatar
Default Re: which ignition is better? (91hatchcivic)
i dont know about jacobs but i had the msd and i think it worked pretty well.
Old Aug 7, 2002 | 03:24 AM
88_SC_CRX_Si's Avatar
New User
A well maintaned OEM system puts out around 40,000 volts as it is. Sooo, your probably better off with just sticking with stock, and spending your money on something that will give you a gain. Honda's ignition system are way above most other manufactors(sp). Unless your going ALL MOTOR or FI with alot psi...
Using an aftermarket ignition systems, without the above mentioned. Just turns it into more eye candy, rather then a real performance gain... hehehe
Anyway, it's your car and $$$$, so it's up to you on on how to spend it...
Old Aug 7, 2002 | 05:39 AM
Denny317's Avatar
imo, keep with the stock unless your car is heavily modified...then go with the MSD unit.
95blackEG
Jan 1, 2009 09:44 AM
97tegblk
Sep 11, 2007 07:03 PM
out_of_order
Apr 18, 2004 08:26 PM
92SiBlu
Mar 29, 2004 06:23 PM
Sleek98
Mar 31, 2003 08:25 AM
