Knock Sensor Replacement for 2000 Civic EX
hi, does anyone know how much it would cost approximately to replace a knock sensor on a 2000 civic? how much for just the part? can someone who's never done it before replace it or do i need to take it to the mechanic? thanks
If i remember correctly its around a deep 19mm socket.
The only problem is its on the back of the block under the Intake manifold. I did it once with a couple different length extensions. Id recommend doin it when the motor is warm. but not HOT.
The part itself costs roughly $100-130. I'd try to find a used one.
Did yours break physically? Did the wires get pinched?
Are you just throwing the Check engine light or did you dig around first?
A mechanic would probably charge their hourly rate. But it cant hurt to try it yourself.
coat4gun
Oct 28, 2011 09:08 AM
strider380
Apr 20, 2011 09:21 PM
HondaGSX
Nov 29, 2005 03:58 PM
