Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Alignment - Tein S to HFP
Old Jan 20, 2009 | 05:39 PM
kartman5's Avatar
Default Alignment - Tein S to HFP
Just had a new alignment after going back to HFP suspension from Tein S springs and
OEM struts:
Front - normal
Camber - Rear - left - -1.6
right - -1.1
normal range 0.3 to -1.5
Toe - left - 0.15
right - -0.15 (right corrected to 0.15)
notmal range 0.05 to 0.25
I'm going to live with the slight increase in camber on the left rear.
Old Jan 20, 2009 | 05:43 PM
K5^'s Avatar
K5^
Brand New
Default Re: Alignment - Tein S to HFP
Wait, your RR camber fell out of specs with the hfp? What was it with the Tein?
Old Jan 20, 2009 | 06:58 PM
kartman5's Avatar
Yes, but I'm not worried about the small bit of extra camber on the rear left. The rest of the
specs are within normal limits. With the Tein S springs I believe the rear camber for both
sides was near -2.0 or greater. I would of had to address the camber and I like the HFP system much better.
Old Jan 20, 2009 | 08:56 PM
6SPDK20's Avatar
I'm running HFP suspension but changed the coil springs out for TEIN H springs. It dropped my FA5 1 1/4" total in the rear and 1 1/8" total in the front. It rides relatively smooth but stiffer as well.
Old Jan 21, 2009 | 04:12 PM
s2kc's's Avatar
thats what i did...
btw, do you have pics of your car dude?
Old Jan 21, 2009 | 06:33 PM
kartman5's Avatar
With the Tein H springs, did you have to correct the camber in the rear?
Old Jan 24, 2009 | 03:51 PM
K5^'s Avatar
K5^
Brand New
I would assume so. What is the difference in height between the S and H techs anyhow?
Old Jan 26, 2009 | 03:09 PM
6SPDK20's Avatar
Yes I have photos. Check out my page on cardomain. My user name is "moch69" and I can be found in the 2009 Honda Civic category. My car is the first one on the 2009 Honda Civic list.
Old Jan 28, 2009 | 04:08 PM
6SPDK20's Avatar
Forget the teins.....they ruined the ride quality for just 1/2" extra drop in ride height. The HFP suspension rides real well and lowers the car around 3/4" all the way around. Once it settles it will probably be about 1" total drop.
Old Jan 29, 2009 | 09:45 PM
K5^'s Avatar
K5^
Brand New
I know, I'm a fan of the HFP's and hope to pick a set sometime soon, one of the downsides to it is the weak drop that it gives.
Old Jan 29, 2009 | 10:15 PM
kartman5's Avatar
Can't say enough about my HFP suspension. A big improvement!
HondaGSX
Oct 19, 2008 02:32 AM
nitroaccord105
Jun 9, 2007 04:45 PM
xbn83
May 15, 2005 01:03 PM
