Suspension & Brakes Theory, alignment, spring rates....
ctr calipers problem
Old Jan 20, 2009 | 02:00 PM
tico_ek9's Avatar
Default ctr calipers problem
I'm having trouble with my rear calipers...I have the CTR 32mm 5-lug conversion on my 2000 Civic Hatch.
My rear brakes lock up then I release the pressure from the bleedoff valve passenger side & they both release.. I can drive around almost all day.Then the next day they are locked up again.So I have to release the pressure all over again!
I bleed all the brakes & even swapped the rear calipers with my boys (same kind)
& it continues to do the same thing..
Can anyone help or suggestions
Old Jan 20, 2009 | 05:18 PM
highroller54's Avatar
Default Re: ctr calipers problem
master cylinder or the rod in the booster is overadjusted, check the brake pedal adjustment also.
When the brakes are locked on lossen off the two mounting bolts to the master if they get free then one of those is overajusted.
Old Jan 20, 2009 | 11:23 PM
tico_ek9's Avatar
thanks I'll try it out ...
BakedAlex
Suspension & Brakes
Nov 9, 2015 07:50 PM
umair
Oct 18, 2011 08:40 AM
yecora
Jul 20, 2007 10:12 AM
sleepin91teg
11
May 31, 2005 12:09 PM
