Acura OEM Parts
Old Jan 20, 2009 | 01:40 PM
beyondstock's Avatar
Default Acura OEM Parts
Well I'm needing some seals and I want to use OEM parts, however; every site I navigate through doesnt give me all the seals I need. i'm looking for the camshaft seals (revised part number 91203-PR4-004) I'm also looking for the passage side seal and the diagram only shows me the driver side seals. They are probably the same but i dont have a local dealer so I can just drive to town and make an order.
I like felpro and I know thier seals are usually quality products, has anyone tried thier camshaft seals?
If someone knows the seals on acuraoemparts.com or sonacuraparts.com or oemacuraparts.com are using the revised seals then I will just make the order there.
Also is the passanger side cam seal the same as the two on the driver side?
Thank,
Raymond
Old Jan 20, 2009 | 03:44 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Acura OEM Parts
What is this revised camshaft seal part number? I've always used these parts and never had a problem:
91213-PR3-004 OIL SEAL (29X43X8) (ARAI) $5.19 (2 required)
12513-P72-003 PLUG, CYLINDER HEAD (right side cam seal) $5.44
Prices are from Carland Acura www.acuraautomotiveparts.org
That cylinder head plug is the redesigned cam plug that is plastic with o-rings instead of just rubber that is prone to leakage. I've had that plug in my cylinder head since January 2003 with no issues.
I was not aware of any revised camshaft seals. Carland Acura doesn't even list that as a valid part number.
Old Jan 20, 2009 | 04:59 PM
yeah I looked everywhere for the revised part but never found it. The only place I found it was doing a google search and never found a true "cam seal" but here is a link that I found where I read about it
http://www.enginebuildermag.com/Arti...cura_b18a.aspx
I was just looking for a cam seal and came accross that site
Old Jan 21, 2009 | 06:46 AM
also when I do a google search on the part number 91203-PR4-004 I find its physically bigger than the on you listed. Its 24x43x9
91203-PR4-004 (revised seal) also interchangable with 91203-PFB-013 = 27x43x9
91213-PR3-004 (original seal) = 29x43x8
here is a link to the revised seal = http://www.autodynamics-honda.com/hopr4case.html
Old Jan 21, 2009 | 09:51 AM
Community Builder
Wait, is this for a DA Integra? Disregard the info I posted above then, as that is for a 94 DC2 B18C1 engine.
Carland Acura lists 2 part numbers for the DA B18A1 camshaft seals:
91203-PFB-013 OIL SEAL,27X43X9
91203-PG6-003 OIL SEAL (27X43X9) (NOK)
The 27 should be 27mm inside diameter on that seal. The original seal (and what 94-01 Integras use apparently) has a 29mm inside diameter.
Are you sure that DA's used the PR3 seal originally? I did not see any technical service bulletins on Acuraworld.com's TSB Info page.
Old Jan 21, 2009 | 10:11 AM
yeah I need to measure the camshaft or seal to make sure. It seams that seal is only good for 90-91, however; the articles I'm seeing they are saying all B-series...
I dont know if it has a pr3 seal in it or not, either way we know the seal that needs to go in it should be the PFB-013. Is the PG6 seal the same?
Old Jan 21, 2009 | 01:10 PM
Community Builder
It's the same size, so it should work.
Now I've never had a problem with the 29mm oil seals leaking on my B18C1, and I've replaced them twice in the past 180K+ miles. I wonder if B18A cams are just a hair smaller diameter than B18C1 cams, hence the need for the smaller seals?
raverx3m
Jun 2, 2014 11:29 PM
stackz
Jun 11, 2009 10:59 AM
92SleeperH23
Nov 13, 2006 07:10 PM
robert1947
Jun 30, 2005 05:43 AM
