DasaniB20T's Massive Build Sellout !! 56K NoNo over 40 pics
I have parted with the 1998 Integra Type R, and picked up a 02 RSX type S.
So everything has to go prices do not include shipping. I have spent over a year gathering up all these parts and was about to put it all in a few days ago.
Time for K!
Sorry for all the pictures, But I want to be detailed as possible.
First off I have a LS/VTEC BUILT MOTOR Fully assembled ready to drop in!
Benson sleeved LS assembled by Fluid Motorsports in Tacoma WA. The BLOCK was purchased by GSRHB7.
Everything has all new gaskets
Port and Polished Type R head (Purchased from Nate in Bellingham forgot his username) Hot tanked, and resurfaced.
• Jun Valve Train
• Skunk2 Pro1 cams on Venom Adjustable Cam gears
• Skunk2 Intake Manifold
• Type R Throttle body
• EVO Intake manifold gasket
• Precision 1000cc injectors
• Hayame Fuel Rail
• AEM Fuel Pressure Regulator
• Type R Valve cover Cut for cam gears.
• Cometic 84mm LS/Vtec Head gasket .30
• ARP HEADSTUDS
• ARP MAIN STUDS
• ARP ROD BOLTS
Everything has ZERO miles
1997 LS B18b1 block
• 84mm Bore
• 9-1 CP pistons BRAND NEW CP RINGS
• Eagle Rods
• Benson balanced LS crank
• BRAND NEW ITR oil pump
• BRAND NEW ITR water pump
• ACL bearings
• Z10 Block GIRDLE
• TODA Timing belt
• Moroso Oil Pan
This thing is ready to take what you want to hand it lol.
SOLD
GSR Transmission with Type R LSD installed
*SHIFTS LIKE BUTTER
*1200 miles on it, removed when I Sold the car. Year = 1997.
All new syncros, measured right.
Rebuilt by an acura tech, VERY CLEAN. $950
XTD Stage 4 Clutch BNIB $159
Treadstone intercooler 3inch inlet 3int outlet TR10 BNIB $280
• Core Size, 10.5" X 26" X 3.5"
• Overall length 36"
• 3" inlet/outlet
• 1000 CFM flow rate
• 666 HP efficient
• less than 1 psi pressure drop
Gator Stage 3 axles SOLD
GSR Transmission of a 95 SOLD
Golden eagle Scatter shield Bronze SOLD
Full race traction bar SOLD
Brand New Neukin Manifold QP T3 flanged with a 38mm waste gate flange. SOLD
Type R Flywheel - Doesn't need a resurface SOLD
Time for K!Sorry for all the pictures, But I want to be detailed as possible.
• Jun Valve Train
• Hayame Fuel Rail
• ARP HEADSTUDS
• ARP MAIN STUDS
• ARP ROD BOLTS
1997 LS B18b1 block
• 84mm Bore
• Eagle Rods
• ACL bearings
• Z10 Block GIRDLE
• TODA Timing belt
• Moroso Oil Pan
SOLD
*SHIFTS LIKE BUTTER
• 3" inlet/outlet
• 666 HP efficient
bump.... all parts are legit.. have seen in person... good seller.. buy these parts so we can boost his rsx... lol
do you hav any current pics of the gsr/lsd trans? hav u had any issues w/it, any probs whutsoever? what year did it come from ? ETC
thanks.............Dan
to be honest with ya i bought it from B18c1turboedEK And didnt get to use it. Was going to be on my built motor for the type r but I sold it.
Also bought the traction bar from him and everything looked GREAT.
http://www.hondamarketplace.com/show...b18c1turboedek
make an offer
i really dont want to seperate. but i will part the head from the block and the intake manifold from the head.
its never been ran, u see the pics. tell me what u want included.
i really dont want to seperate. but i will part the head from the block and the intake manifold from the head.its never been ran, u see the pics. tell me what u want included.
