new bearings needed?
Old Jan 20, 2009 | 11:47 AM
redracerk20's Avatar
Default new bearings needed?
i spun a bearing in my Y7 block, can i use some of my friends old bearings? he says i have to buy some new bearings, cuz you cant use old ones....is this true? i have to get new bearings? or can i use my friends old bearings.....
thanks in advanced!!!
Old Jan 20, 2009 | 12:01 PM
92_white_rabbit's Avatar
Default Re: new bearings needed?
Why would you even want to use old bearing and the answer is no you cant use old bearings
Old Jan 20, 2009 | 12:15 PM
why not......ppl say you cant use same gaskets, yet alot of ppl do it.....just explain why not......cuz i dont have the money for some new ones....unless you got a deal.... trade some parts lol
Old Jan 20, 2009 | 12:45 PM
jdmdikk's Avatar
so heres the thing..u will need new bearings and dont get any yet until the motor is taken apart so that u can see what size bearing is needed(standard or oversized)your crankshaft might be scratched and need to be grinded down evenly and might require different bearings instead of standard 1's..i had this problem and decided to buy a used crank that was in good shape for $75 (dohc ls)..
Old Jan 20, 2009 | 01:05 PM
NonovUrbizniz's Avatar
Loved
All the bearings in your engine can be different sizes. using someone else's old bearings is not an intelligent option.
You COULD install them and check your clearances with plastiguage but really it's pointless... get ACL's for 90 bucks.
Also if you spun a bearing as mentioned you really need to get the mains and the crank itself checked to see if it needs polishing/line honing which it probobly does. and even then sometimes you can end up with out of spec block even with the largest available bearings.
I'm all for ghetto cheapness... and frankly it probobly will work if you slap it back together with bearings that are off... but for how long? and will it now cause the complete destruction of the block?
Old Jan 20, 2009 | 01:07 PM
jdmdikk's Avatar
the motor will knock and then you will spin more bearings since they will not be tight .
young-gun92eg
Feb 17, 2014 08:38 AM
gmacarize
May 26, 2007 02:30 PM
92hatchattack
Jun 7, 2005 09:21 AM
Licensed2Spool
Sep 19, 2003 09:24 AM
