Would a ZC tranny....
....fit on my D15B with no problems? I heard that I might need a half shaft to make it fit, because the D15B is different? I don't think there would be a problem but any info would be appreciated. Thanks.
First, check the back of your block to see if you have the screw holes for the intermediate shaft to screw into.
Some blocks don't have the holes at all, some do, and other have the holes, but they aren't threaded.
You can still use the ZC tranny even if you can't use the intermediate shaft. You will need ot open the tranny and swap out the diff for an SI type so that the regular non-intermediate shaft axles will work. You probably have to change out the seals as well.
