what i need for my b16a2 to get in my ef hatch??
I got the complete changeover im just a little short of knowing what all im really gonna need to put it in. I know i need motor mounts im gonna order wheres a good place to get hasports for cheap? I know the cable to hydraulic kit i need but idk the best place to order that from either? I have heard rywire is a good place to order the jumper harness. What else am I leaving out?
I have a brand new rywire complete obd0 to obd1 jumper, vtec sub harness and obd0 to obd1 dizzy jumper harness's. I paid over 2 and never used it. ill sell it for 150.
other than that its a regular bseries swap. mounts, linkage, crossmember. I never could figure out the vacuum thou. good luck
vacuum isn't to terrible - you can down convert to obd0 - reccomend going obd1 and getting a chipped (and tuned eventually) ecu
but yes mounts and linkage - if you have clearance issues modify the crossmember or replace it...
and what with axles with hydro tranny?
my friend used axles from b16a2 and they were to long, on tight corners something was blocking;
i'm planning to run 400-500hp so i want something stronger than oem, but i don't know which one axles i'll need
EKlscoupe_98
Aug 26, 2008 02:59 PM
