Leaking injector
Old Jan 20, 2009 | 09:13 AM
mikeszutu's Avatar
Icon6 Leaking injector
Hey guys,
I notice this problem for awhile but, I could never figure out where it was coming from. Originally it starts when I fire up my car from cold and, turn on the heat. I could smell a raw gas coming in the vents and, if I go outside I could smell it also. This only occurs when I pull the air from outside.
Recently I looked under the hood and notice gas on my fuel injector and, I made sure by poking at it and smelling it.
What should I do?
Old Jan 20, 2009 | 09:44 AM
masterkill455's Avatar
Default Re: Leaking injector
your injector O rings have gone bad. Replace them as a set for all 4 cylinders.
Old Jan 20, 2009 | 10:18 AM
mikeszutu's Avatar
How hard is it to do this?
Old Jan 20, 2009 | 10:25 AM
not too big of a deal, gotta pull the fuel railand unplug the injectors and one by one pop them out get the o ring off and pop on a new one. I havent done this personally on a honda engine so you may wanna hold off til someone that has done seals pops up
Old Jan 20, 2009 | 02:00 PM
Perfectionist's Avatar
FWIW, on my old '90 Civic Si, one injector developed an external leak. It was obvious by the slight accumulation of dust that stuck to the wet fuel over time. Replacing the o-rings and manifold seals is a breeze. Just make sure to lubricate them first so you don't risk tearing them.
Old Jan 21, 2009 | 12:29 AM
4671 Hybird's Avatar
What year is your Accord? I've done a few o-ring jobs on 94-97 models and it's quick and easy.
Old Jan 22, 2009 | 10:09 AM
mikeszutu's Avatar
It's a 91 Accord..
Old Jan 22, 2009 | 02:21 PM
Never did a '91 but I've heard through the grapevine it's not very difficult either and a relatively quick job. Take a pic of your injector rail and post it and we can walk you through it.
Old Jan 24, 2009 | 03:01 PM
mikeszutu's Avatar
I have uploaded the images of my fuel injector..seems like it's coming from one leaking injector
Old Jan 24, 2009 | 03:05 PM
mikeszutu's Avatar
The leak is coming from the second injector from the left. Should I take it to the dealership? or, do it myself?
Can someone guide me?
Old Jan 24, 2009 | 04:18 PM
take off the gas cap to release any built up pressure and then carefully disconnect all wires and hoses that need to be unhooked. Take the bolts out of your fuel rail and pull it off. NO SMOKING OR SPARKS OR FLAME! gas will come out. now remove each injector and carefully pry off the old O rings (theres an upper and a lower) and dont scratch up the injector doing so. Lube the new O rings with a little vegatable oil and pop them on. Do it one injector at a time to reduce confusion. Put it all back and enjoy non leaking car.
Old Jan 25, 2009 | 11:10 AM
I would put the O-rings in the bores rather than slip them on the injector. Then just line up all the injectors and slowly push them back in. Your pics look very similar to mine, it's mainly just taking off the 3 small nuts, lifting off the rail, and changing the offending o-ring. Any o-rings that stay on the injectors, put those back in the bores so they don't tear. A little grease or vaseline is helpful too, as stated above. All in all, even for a first timer, you're looking at a 25 min job, tops.
Edit: Mine only had one seal but two shouldn't be much different.
type Gendy
Feb 26, 2004 08:27 AM
JDMlyfestyle
Oct 17, 2003 10:43 PM
lowboost civ
Apr 22, 2003 08:47 AM
Brolli007
Nov 18, 2002 08:48 AM
EGh22aEG
Mar 29, 2002 04:11 PM
