Lots of B-series parts/Mild turbo part out!
Like the title says, I have too much Honda stuff and I need it gone.
1 B16 crank (Good as far as I know and used) - $50 Shipped
1 Greddy Type-RS BOV with pipe (Used but still in good condition) - $125 Shipped
2 Sets of B-Series cams (2 sets of stock B16 cams and are in great condition if not mint, and a pair of GSR cams still in good condition) - $30 (B16) and $40(GSR) OBO Shipped
A **** ton of B-Series cam gears (Stock) - $5 each Shipped
1 B16 Intake manifold (used with no sensors) - $35 Shipped
A set of (4) Stock B16 pistons and rods (All pistons are bad, but rods are still good) - $30 Shipped
1 Ebay Tial knockoff 38mm wastegate with an 8psi spring with all the fittings and no fire ring (used and works fine) - SOLD!
1 (Used) Cast iron turbo manifold for a T3 frame turbo and a 38mm wastegate that bolts up to any B-Series head - SOLD (Locally)
1 B-Series (Don't know which ones) oil pickups - $20 OBO
1 Set of B-Series (Used and cleaned) rocker arms - SOLD!
3 (Used) [Eagle?] Rods (5290H.O) for a B16 - SOLD!
3 (Used) SRP Pistons for a B16 (9:1 or 9.5:1 compression, 81.5mm or 20 over, and they come with wristpins but no locks) - $40 Shipped
1 Ebay (SportJDM or whatever the hell you want to call it) T3/TO4E .57 Trim turbo (Has worn seals but has no shaft play) - SOLD!
B-Series water inlets - SOLD!
A GSR head complete with cams, cam caps and rails, cam gears, valve cover, and VTEC solenoid. (no dizzy, or cam cap/rail bolts) - SOLD!
http://www.hondamarketplace.com/show....php?t=2478141
1 B-Series oil pans (Not tapped and no drain plug) [I will clean them up as in wash them in a solvent tank] - SOLD!
A set of cam caps that came off a B18C5 - $45 Shipped
1 B16 bare block (stock bore with great looking sleeves, no crank, no maincaps) - SOLD!
1 P73 (Type-R) Intake manifold (Basically new) - Sold!
1 B16A3 shortblock (With original pistons, rods, and crank) except the sleeve is cracked in cylinder 3 - $250 +shipping
*All prices are OBO!
I'll also take trades too! I need A Tial (or other brand name) 38mm wastegate, and a decently large intercooler, a B series lightweight flywheel, a B-series fuel rail, a set of (4) peak and hold (Low impedance) 750cc or larger injectors, and a fuel pressure regulator!
Either PM me or E-mail me at jasony0630 at hotmail dot com.
Thanks for looking.
Thanks for looking.
