head gasket
Old Jan 19, 2009 | 08:45 PM
b17 rolla's Avatar
Default head gasket
so i posted a while back about me screwing up on my head gasket tightening sequence and pounds of torque so i got a new head gasket got my head checked for warp and i even sprayed on a copper gasket torqued to 80 and used the correct sequence and still got water in the cylinders and before the water was in three and four and now its one and two so no crack no warp in the block
so my questions
could my arp studs be stretched and need more torque
is there some kinda seal
could i have put it on wrong im pretty sure it says up tho
Old Jan 19, 2009 | 09:12 PM
SOHC_4dr's Avatar
Default Re: head gasket
your head may have been checked but did you have the head decked so it was true and strait? if not then do that. is it an oem honda gasket? you should use oem honda but to each his own. did you replace your head bolts? they cant be reused
flozella
Aug 30, 2014 07:20 PM
eastbay925
Apr 7, 2009 09:44 AM
tom4691
May 17, 2007 08:46 AM
Lewcis
Jun 24, 2004 11:02 PM
DLB1994
Feb 23, 2002 10:17 PM
