Ideal springrate for EG hybrid
Old Aug 6, 2002 | 05:56 PM
92SiB18C1's Avatar
Default Ideal springrate for EG hybrid
I just did a swap GSR into my 92 hatch. I was wondering with the extra weight, what's the best set up for lowering spring. 350 front, 500 back? And what kind of brand do you recomended. Thank you
Old Aug 6, 2002 | 06:59 PM
eg6ajk's Avatar
Default Re: Ideal springrate for EG hybrid (92SiB18C1)
usually you want higher spring weight upfront as this where the weight is. as you most likly know civic/integras are 60/40% as far as balance therefore the springs can be matched in the same way to achive fairly good handling
high rear spring rate may lead to unwanted oversteer in some setups and can be dangerous on streets.
F400-R300lbs/in is the usual or F10-R8kg/mm
dwillms
May 24, 2010 07:48 AM
shoryuuu
Suspension & Brakes
Jan 27, 2007 05:49 PM
2DoorBandit
Suspension & Brakes
Feb 25, 2006 04:55 PM
onekoop
Suspension & Brakes
Aug 11, 2005 07:59 PM
eg6beater
Jul 31, 2004 09:51 AM
