Suspension rates for drag car
Old Jan 19, 2009 | 04:39 PM
Mr. Em1's Avatar
Default Suspension rates for drag car
hey guys im lookign to upgrade my suspension. i was wonderign what spring rates would be best for my setup. im looking to get about 700whp in my 99 civic si
Old Jan 19, 2009 | 10:41 PM
MindLess311's Avatar
Default Re: Suspension rates for drag car
7 14 and 12
Old Jan 20, 2009 | 03:18 AM
boostedcivicsir's Avatar
Mr. Badwrench
ed from progress had me go with 450's in the front and 1000's out back. those are in lbs. not kg.
coming from a shelf progress kit, it is night and day.
Old Jan 20, 2009 | 06:09 AM
Mr. Em1's Avatar
interesting, what would that convert to into lbs? i was looking to go with skunk2 drag launch coilovers
Old Jan 20, 2009 | 09:46 AM
JDMThoughts's Avatar
From: Standing on the corner selling cocaine, rippin shows live on stage for hoes yellin my name
Are you referring to the old skunk drag springs? I have used the Omni Power Drag setup and I have ground controls with 1000lb springs in the front 1200lb springs in the back mated with revalved konis, which is working really good for me. I do plan on trying the Progress units, a lot of people appear to be having good results with the progress suspension setups.
Old Jan 20, 2009 | 10:02 AM
Innes's Avatar
we have been running 450 lb front springs and 700 lb rear spring with our Strange Coilovers -- they have worked well for us for the past 3 years
shock dampening is very important as well in addition to just the spring rate -- the shocks do a lot of the work.
Old Jan 20, 2009 | 10:05 AM
miller's Avatar
bullshit, throw some 200000000 lbs springs in the back and raise it up as high as you can and you will be fine.
Old Jan 20, 2009 | 10:09 AM
rota92
Guest
Posts: n/a
I was on a 450 front and an 850 rear and loved it, as said above the valving is what matters. Any spring is the wrong spring without the proper valving to suit your application.
Old Jan 20, 2009 | 12:44 PM
Mr. Badwrench
when you go to do the progress setup, talk to ed or joey there and have the shocks setup to your car.
i had the off the shelf kit, it worked ok for the 540whp i was making, and even with that power level, ed said i was asking alot out of the shocks.
since i have gotten with them about the spring rates, one of my mid season upgrades were to have the shocks revalved. and i think it is one of the best things/ biggest differences i have noticed.
i had a problem with the car unloadingon a launch and the front staying up. also unloading on shifts.
this is all where the revalving comes into play.
to ed and joey at progress.
Old Jan 20, 2009 | 04:30 PM
allmotaeg6's Avatar
would anybody happen to have the contact info for ed or joey at progress?
Old Jan 20, 2009 | 04:34 PM
Mr. Badwrench
http://www.progressauto.com/
on the front page.
Old Jan 20, 2009 | 10:08 PM
Mr. Em1's Avatar
well i just became a part of team skunk 2 and wanted to take advantage of that opportunity and was going to use my kyb agx struts with a set of their 14 or 18k rears and was mainly wondering which ones i shud use in the front
Old Jan 21, 2009 | 07:33 AM
Innes's Avatar
the AGX shocks will have no chance of hell keeping up with a 14k or 18k spring rate -- that is what we are all saying, you can put the stiffest spring you want on the car but the dampening will not be able to do its job effectively and will probably hurt you more than help you
if you are looking to still run this setup I would suggest getting Koni Yellow Shocks since they are a bit better right out of the box and with the Koni custom shop you can easily have them revalved in an attempt to match the spring rate if you choose
another issue you will run into using the AGX shocks and a Skunk2 Slip-on Coilover is the height adjustment -- if you set the height of the coilover too high the shock will be extended too much already and won't be able to do its job of dampening at all due to not enough movement - this is why true coilovers can be a better option because of regardless what height you set the vehicle at the shocks will still have the same amount of dampening travel to do their job
there are also great inexpensive full Drag Coilover options on the market from Blox Racing, Omnipower and D2 and although may not be necessarily valved exactly as needed they will do a lot better job than a high spring rate slip on coilover with standard off the shelf performance shock
Old Jan 21, 2009 | 08:40 AM
Mr. Em1's Avatar
true, i figured the agx's wudnt be able to cut it, when i sell them i can look for somethin else im tryin to get a few other parts suspension is least of my worries right now
WannaRun??
Jun 18, 2012 12:22 PM
jamaljbenoit
Mar 14, 2012 01:04 PM
JDM809
Suspension & Brakes
Jul 11, 2011 12:18 PM
a1320addict
Jul 21, 2006 01:27 PM
