Keep popping fuses, no tail lights.
Old Jan 19, 2009 | 03:27 PM
d16y8crx's Avatar
Default Keep popping fuses, no tail lights.
So everything was cool, driving on the freeway, 90 CRX Si, didn't hit a bump or anything and the 10 amp fuse for the tail/dash/license lights went out. Switched it, lasted about 3 minutes then popped. Got home, changed it again, and now it goes out instantly. I've looked at all the wiring, i took out all the parking bulbs, disconnected the dash lights, and disconnected the license plate lights. All the connections were dry, and the bulbs were fine. i put in another headlight switch assembly and disconnected the light brightness controls. Same thing.
Any ideas?
How can i tell if a socket is bad, and do they just go out like that?
Thank you.
Old Jan 19, 2009 | 03:44 PM
roadsqueegy95's Avatar
Default Re: Keep popping fuses, no tail lights.
i know u said u checked all the wires, but deff sounds like a ground problem
Old Jan 19, 2009 | 03:46 PM
StraitRunna's Avatar
ya could be a cut in a wire sumware thats shortin out on sum metal jus run trough and check all your wires for cuts
Old Jan 19, 2009 | 04:30 PM
Kevin B's Avatar
Most likely you have a short somewhere. Disconnect all associated lights or connections for that fuse, put a new fuse in and start putting back one light or connection at a time. Check the fuse after each light or connection to see when the fuse blows. Then trace the wires to see if there is any bare wire.
Old Jan 19, 2009 | 04:47 PM
d16y8crx's Avatar
Yea thats what i did. I took out all the bulbs for the front and rear tailights, the license plate lights, the gauge cluster connections, and it still popped. I changed the headlight switch and same thing.
When i put in a fuse the second time and it stayed on for 2-3 minutes, all the lights were working correctly.
Old Jun 14, 2009 | 08:09 AM
lucent187's Avatar
New User
hey did you ever fix your problem with the tail lights cause im having the same problem?
Old Jun 14, 2009 | 08:43 AM
h224thgensedan's Avatar
check your horn circuit and horn fuse under the hood.
Old Jun 14, 2009 | 06:58 PM
290allen's Avatar
had the same thing happen to me when i was like 16, turns out my radio wires were shorting. i believe the radio illum is on the same circut. i would check it out.
(this is why i use shrink wrap on my connecions now)
Johnoolo
Jan 14, 2014 12:24 PM
Capt. Jimbo McSubipants
May 21, 2009 09:15 AM
twiztid00002
Nov 10, 2008 07:42 AM
95silverteg
Sep 30, 2008 04:48 AM
tdizz07
Sep 20, 2007 07:45 PM
