Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
CRV Driveshaft
Old Jan 19, 2009 | 01:40 PM
b20integrapower's Avatar
Default CRV Driveshaft
I was under my gf's 98 crv and noticed the driveshaft wasn't there. Was AWD an option for crvs? Or did someone not put it back when they repaired the car(this is the only reason i can see why it would be missing)
Old Jan 19, 2009 | 06:28 PM
Ross 2.0's Avatar
In a Junkyard near you.
Default Re: CRV Driveshaft
it's probably just a 2wd. Does it have a rear diff?
Old Jan 20, 2009 | 09:19 AM
ricebike's Avatar
yes, there were cheaper, only FWD models, in the small SUV segment in any manufaturers
i've seen similar vehicles, Ford Escape/ Mazda Tribute/ Toyota Rav4, that i was following on the road & thinking WTF?!?! --> a rear open cage that's missing a rear differential and axles
here's the specs from vehix for your 2wd/FWD model:
Mechanical Features
2.0L DOHC aluminum alloy 16-valve I4 engine (1998)
Multi-point programmed fuel injection (PGM-FI)
4-speed electronically-controlled automatic transmission w/Grade Logic Control System Front-wheel drive
4.36 final drive ratio
4-wheel double wishbone suspension
Front/rear stabilizer bars
P205/70R15 all-season mud & snow SBR tires
Exterior spare tire carrier w/tire cover
Variable-assist pwr rack-and-pinion steering
Pwr-assisted front disc/rear drum brakes
15.3 gallon fuel tank
Last edited by ricebike; Jan 20, 2009 at 09:49 AM. Reason: addin' some info to confirm
Old Feb 23, 2009 | 05:45 PM
whoa didnt see this till now. It has a rear diff and axles. I think someone didnt want to replace it.
Old Oct 6, 2010 | 07:51 PM
murdered sol's Avatar
yeah my girl just bought a V and they advertised it as FWD. We took it home and discovered that it was an AWD model (had rear diff and AWD tranny) so we called the dealership and asked them about it. They told us that it had a bad driveshaft and instead of buying a $900 replacement, they just took it out and called it a FWD. They also said that its actually pretty common to do that
Built B16A
Honda Motorcycles
Jul 31, 2008 08:49 AM
ED9man
Jul 18, 2006 09:35 AM
577HondaPrelude
145
Oct 27, 2005 07:55 PM
ykracing
Nov 12, 2003 09:38 AM
Fat Matt
Mar 17, 2003 12:30 PM
