GSR cluster's interchangable?
Old Jan 19, 2009 | 01:24 PM
mannydhanju's Avatar
Post GSR cluster's interchangable?
i have a 95 gsr cluster and i think i bought a 99 cluster i hooked it up but my gas gauge did not work as i had a full tank of gas and neither did my hot/cold... i was told that obd1 cluster dnt match with the new tegra's... anyone ever come across this problem..
Old Jan 19, 2009 | 08:26 PM
XslickwhitetegX's Avatar
Default Re: GSR cluster's interchangable?
u need do use the search function, it will answer your problem.. but I'll give you a hint, "green film swap".. its easy fix.
Old Jan 19, 2009 | 09:40 PM
pkdog167's Avatar
or repin the wire
Old Jan 20, 2009 | 07:55 AM
i have put cluster in and now my speed gauge is not reading rite... i tried taking the needle pin off and resnapping it back on at different angles but still nothing... i even tried to turn it clockwise or counterclockwise and stillt didnt work... i beleive there is a sweet spot but i can't seem to hit it... or is there a easier way to do this
berger1302
Jan 6, 2010 06:54 PM
maxwellmercer
Oct 26, 2008 10:03 AM
blah11
Dec 20, 2007 08:30 PM
5thgencivicr
Jul 7, 2005 05:35 PM
