Welding V-band to exhaust housing
Old Jan 19, 2009 | 11:55 AM
TurboFocus's Avatar
Default Welding V-band to exhaust housing
Hey guys what kind of filler rod do you use when welding a v-band flange to a turbo exhaust housing.
Thanks
Jim
Old Jan 19, 2009 | 12:05 PM
Nick Z32's Avatar
Default Re: Welding V-band to exhaust housing
well... what kind of metal is it?
ss to ss
Old Jan 19, 2009 | 12:06 PM
TurboFocus's Avatar
The exhaust housing of a turbo is cast and its a ss v-band would ni-55 filler rod be good
Old Jan 19, 2009 | 12:22 PM
Nick Z32's Avatar
wait.. your trying to weld the vband to the cast?
edit: sorry haha i didnt read the title but yeah that's the only filler you could use , its not gunna be pretty tho
you can also use Ni-99
Old Jan 19, 2009 | 12:25 PM
TurboFocus's Avatar
Yes!
Old Jan 19, 2009 | 01:15 PM
m R g S r's Avatar
preheat the turbine housing also
Old Jan 19, 2009 | 03:27 PM
TurboFocus's Avatar
Yes i did some more looking and i preheat the housing to 400 degrees and im gonna use ni-99 filler rod.
Old Jan 19, 2009 | 03:34 PM
90blackcrx's Avatar
You can use stainless filler, or mild steel. I prefer mild steel due to the strength, and if you look around it actually looks pretty nice if done right.
Old Jan 19, 2009 | 03:36 PM
boostedgsr1234's Avatar
I bolted a normal 4 bolt flange to mine and tig welded the v-band to that, way Easier, plus, ur supposed to ore-heat the housing, then weld it, then let it cool very slowly, at least that is what I was tought
Old Jan 19, 2009 | 03:51 PM
k24em2's Avatar
If your turbine housing is cast steel....309L should be used if the vband is stainless
if its cast iron Ni99 could be used
Old Jan 19, 2009 | 03:54 PM
90blackcrx's Avatar
Preheat, then though in a bucket of sand.
Old Jan 19, 2009 | 04:01 PM
90blackcrx's Avatar
True but you can use mild steel filler as well and it will be fine.
Old Jan 19, 2009 | 04:23 PM
m R g S r's Avatar
To the OP:
Are you talking about welding a Wastegate V band to the turbine housing, or just the exhaust outlet V band?
Old Jan 19, 2009 | 05:13 PM
k24em2's Avatar
309L is still a better choice if the flange is stainless.
Old Jan 19, 2009 | 05:24 PM
GTibunny16v's Avatar
Ive used 309L and Ni-99 to weld stainless vbands on turbine housings. Both are holding up fine to this day. I welded it inside and out though. I put the turbine housing in the oven on the rack. I also left a metal bucket with sand in there to heat up. Once I was done welding the housing, I put it into the sand and turned the heat on the oven down to 250 for half an hour and then off and let it cool.
Old Jan 19, 2009 | 05:41 PM
90blackcrx's Avatar
True.
Old Jan 19, 2009 | 05:52 PM
CVC9216's Avatar
I've tig and mig welded plenty of cast iron without pre or post heat and I've never had a problem. I would use 309 also. Some exhaust housings come with the v-band flanges welded on
Old Jan 19, 2009 | 05:59 PM
Nick Z32's Avatar
^ well then you got lucky i didnt crack
but Ni-55 and Ni-99 is made specifically for welding cast... why wouldnt you use it
Old Jan 19, 2009 | 06:33 PM
90blackcrx's Avatar
Not kept on hand usually, some places don't stock it, and if I recall I thought it was a lot of money... but I could be wrong. I just use what I have on hand, never once had an issue.
Old Jan 19, 2009 | 07:09 PM
k24em2's Avatar
Nickel rods are for cast IRON.
Most turbine housings are cast STEEL.
Hence, you use a 309L rod if your v-band flange is stainless.
abs0Lut
Welding / Fabrication
Apr 27, 2014 06:15 PM
greasemonkee
Feb 28, 2010 07:37 PM
95delsolz6
Aug 15, 2008 11:27 AM
93c1sol
Aug 28, 2007 06:17 AM
NJIN BUILDR
Jul 1, 2007 05:22 PM
