Suspension & Brakes Theory, alignment, spring rates....
GC Replacement Springs Questions
Old Jan 19, 2009 | 09:58 AM
bopbop93030's Avatar
Default GC Replacement Springs Questions
I'm at GC website and looking for replacement springs for my car but I dont understand what I am looking for.
I ask GC tech and the guy is clueless, so I try asking here.
My OTS springs are
200.64.67 Front 380lb? front
230.64.49 Rear 280lb? rear
In GC website it says springs with street springs, 2.5 ID, 2.25ID and so forth, from there there is like lengths, and I have no idea what lengths my springs came in coz. I did not measure them.
and from there let say I choose 6" there is 0600.250.0850
I do not understand this numbers
Could someone help me please. Thanks!
Old Jan 19, 2009 | 02:07 PM
GroundControlTrevor's Avatar
Default Re: GC Replacement Springs Questions
I would love to help you.
200.64.67-8 inch length, 2.5 inch inner diameter, 380 pound spring.
230.64.49-9 inch length, 2.5 inch inner diameter, 280 pound spring.
My name is Trevor, if you have any questions give me a call. Thank you very much.
530-677-8600
Old Jan 20, 2009 | 07:27 AM
sts38's Avatar
530-677-8600
Hey Trevor...I could use some GC advice.
It seems the 700.250.xxx does not exceed 650lbs.
http://www.ground-control-store.com/...gory.php/CA=49
What if I wanted to try a 700lb spring? Can I get a 6" or an 8" and just adjust
the perch? Would there be any advantages or disadvantages to a 6" vs. 8"?
Or can I find higher rates in a 7"?
Thanks...I appreciate the feedback.
Old Jan 20, 2009 | 09:04 AM
You are right, in a 7 inch, 2.5 inch inner diameter, the highest spring rate available is a 650lbs spring. My opinion is going to be different than others on this forum, but I wouldn't recommend going from a 8 inch to a 6inch long spring. If you are trying to get as close to a 700lbs spring; go with the 0700.250.0650. There is a 0600.250.XXXX available up to 1450lbs also, so there is many different options to choose from.
JDMCIVICMAN1992
Nov 6, 2011 08:44 PM
DefiantGSR
Suspension & Brakes
Nov 25, 2008 07:47 PM
b20mike
Apr 13, 2004 03:02 PM
577HondaPrelude
Sep 29, 2003 02:06 PM
ghettoracer
Feb 7, 2003 11:57 AM
