Eh? sensor? not on a d15b7 but on a d15b2
Old Jan 19, 2009 | 09:46 AM
black picture's Avatar
Default Eh? sensor? not on a d15b7 but on a d15b2
ok so im kinda confused here, im working on my girl friend's car and i have an extra d15b7 to replace her d15b2 that burn oil bad, so i have the two and looking at all the sensor to make sure none was broken and well d15b7 doesnt have this one, on the d15b2 im pretty sure the sensor is the raditor fan correct me if im wrong!
d15b2 (91 civic lx foor door)
d15b7 (94 civic dx hatchback)
ok what should i do because the d15b7 does not have the sensor? im running of to work and dont have the time to do the research for a couple days thanks!!!!
Old Jan 19, 2009 | 10:06 AM
ef_junky's Avatar
Default Re: Eh? sensor? not on a d15b7 but on a d15b2
cause the b7 is obd1 they probably moved it... check your thermostat housin on the b7 i think if i'm not mistaken there will be a sensor or something there its brown i think..... and you b2 won't have it.....
Old Jan 19, 2009 | 10:24 AM
crx_si-r's Avatar
the sensor you are pointing to is the cooling fan switch (engages radiator fan) on the obd0 motors its located where you pointed and on newer d series cars 92-up it has been relocated to the thermostat housing. so you will need to add some wires and extend the plugs that were going to the old plug location and get a new plug that will plug into the sensor on the housing.
Old Jan 19, 2009 | 07:35 PM
cool! thanks you guys!
Old Apr 5, 2009 | 07:52 PM
Remiss's Avatar
thx i was wondering the same thing all day also
Old Aug 7, 2009 | 04:53 AM
civic_driver09a's Avatar
im having the same problem aswell.so where do i get the new plug for the sensor??autozone mabey?
ONEFASTJDM
Jul 16, 2009 10:37 PM
dreadyduck
Apr 29, 2008 10:18 AM
aequitas
11
Mar 20, 2005 09:42 AM
Speedz
Jun 2, 2002 09:25 PM
Ladies Man
Jul 14, 2001 09:35 PM
