Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
how to change AC filter?
Old Jan 18, 2009 | 08:58 PM
tyronne1126's Avatar
Default how to change AC filter?
- does anyone know how to change the AC filter and how to apply the cleaner to get rid of the bacteria?
- pictures would help.
06 Honda Civic 4D
thank youuu....
Old Jan 18, 2009 | 09:36 PM
av911's Avatar
Default Re: how to change AC filter?
http://www.8thcivic.com/forums/engin...e-10-pics.html
Old Jan 18, 2009 | 09:44 PM
redbull-1's Avatar
Are you referring to the pollen filter? The following shows how for a Honda Fit; but, the procedure is similar for most Hondas and Acuras:
https://honda-tech.com/forums/honda-fit-73/diy-dust-pollen-filter-replacement-2292803/
Old Jan 18, 2009 | 09:49 PM
thanksss... feel kind of dumb haha so easy.. any idea how am suppose to apply the cleaner? the guy at honda said to apply something to get rid of the germs..
Old Jan 18, 2009 | 11:12 PM
av911's Avatar
If the air filter box is dirty, wipe it with a wet towel or something. I never had to spray anything.
Old Jan 19, 2009 | 10:23 AM
guinnessstout's Avatar
The best way to avoid bacteria build up and mold is to use the fresh air vent as often as possible.
Old Jan 20, 2009 | 06:30 AM
what do you mean the fresh air vent?
Old Jan 20, 2009 | 07:32 AM
Lewy. Dee Ayy's Avatar
there actually called hepa filters...per honda's...for some odd reason. lol.
Old Jan 20, 2009 | 01:29 PM
pubes2942's Avatar
Just open up your glove box. squeeze inward on the two sidewalls of the glove box, and pull down. these side rubber "nubs" hold the glove box up while its open. prop the glove box up with your owner's manual. look in above the a/c blower assembly, and you'll see a tray snapped into place by two tabs. squeeze in on the tabs again just like the glove box sides -->inward<-- and slide the tray towards you. pull that nasty filter out and make sure you replace the new filter, the same way the old one sat in the tray. *you can spray the filter down with a deoderizer for maximum effect. button everything up and there you go.
-a random lexus technician
Old Jan 22, 2009 | 07:06 AM
spoonfedcrx's Avatar
They're not "hepa" filters. In order to be classified as a hepa filter they need to filter any airborne particles with a size of 0.3 micrometres. They don't so they are not.
Pradox187
Oct 22, 2015 07:21 AM
jhvr001
Honda CR-V & Element
Aug 10, 2013 08:38 AM
techtalk
11
May 1, 2012 12:24 PM
dom93hatch
Jun 27, 2006 07:07 AM
plum
Jul 26, 2004 06:31 AM
