Suspension & Brakes Theory, alignment, spring rates....
Hardrace bushings = FAIL
Old Jan 18, 2009 | 07:40 PM
beanbag's Avatar
Default Hardrace bushings = FAIL
I bought a set about a year ago. Since then, every single bushing I have tried to install has led to a trip to the machine shop for trimming.
Trailing arm bushings were too large diameter and wouldn't press in: Took the bushing to the grinder to take 0.020 off the outer edge.
Compliance bushing: Poor sheet metal work meant that the bolts wouldn't sit flush against the mounting surface. Had to put them on a mill to trim off the extra interfering bits.
Front LCA to shock bushing: This time I got smart and only pushed out my original bushing part way to compare diameters. Yup, Hardrace bushing was larger than this by 0.013". Now I get to go back to the shop again to trim these down. Again.
In summary, these bushings are the shittiest **** that was ever shat out of a butt.
If you don't think so, please buy my set off of me for cheap. $50 OBO for everything minus the aforementioned bushings.
Old Jan 19, 2009 | 12:42 AM
mojo_jojo77777's Avatar
Default Re: Hardrace bushings = FAIL
hmm. I was going to actually order the full set for my itr, but now I'm not so sure. I might have to do more research on them
Old Jan 19, 2009 | 03:41 AM
WERA689's Avatar
I just had a set of their trailing arm bushings installed in my DC4, and there were no issues at all. I suspect that this guy is getting bushings for the wrong chassis...especially if they are ALL wrong in some way.
BTW, my car's handling improved noticeably with the new bushings. Of course, I expected that since the old ones were totally trashed!
Old Jan 19, 2009 | 04:54 AM
^yeah, maybe he got the wrong bushings, because what I've read from other people is that they didnt really run into any big issues. I'm debating to do the hardcore bushings, or just order oem replacement bushings
Old Jan 19, 2009 | 07:33 PM
confidence's Avatar
that sound like the best guess to me as well.
the EF chassis have a larger rear LCA bushing than the eg and ek. although the difference is substantial and it would be pretty obvious he had the wrong bushings.
i replaced all but my rear LCA and rear shock bushings on my ek and had no problems at all what so ever. i did think the compliance bushings were not as stiff as my ES bushing but i have no complaints about the bushing so far. i personally prefer them as they are lower maintenance when compared to the ES bushings and fit like factory. i also don't need to clean and lube them every 6 months or deal with annoying squeaks when it gets cold now!
hard race bushings are the best thing out there IMO
Old Jan 20, 2009 | 05:35 AM
unusual71's Avatar
sorry for the thread jack but... all the kits for the 96-2000 say that the bushings for the front lower control arm only fit in the Si style front LCA. are any of the bushings useable with a non-Si front LCA? or are the LCA hugely different between Si and non-Si models?
Old Jan 20, 2009 | 10:55 PM
xd69's Avatar
The difference between the si and non si LCAs are like night and day. The non si LCAs are cast and use a much smaller shock bushing. The Si LCA is stamped and looks much thicker and is lighter and stronger
Old Jan 20, 2009 | 11:38 PM
.:Made in OC:.'s Avatar
Im guessing he got the wrong set as well. Probably labeled correctly but packaged with a different model. I have not yet heard of issues like this from Hard Race products.
If anyone is interested in purchasing any kind of Hard Race products feel free to shoot me a PM.
Old Jan 21, 2009 | 12:08 AM
beanbag's Avatar
https://honda-tech.com/forums/showth...ight=race+hard
The only other nearby trailing arm bushing size I know of is the DA, and they are 0.2" larger, not 0.02" larger.
Also, I don't know of any honda bushings for the lower control arm that are the same length as the DC2 but 0.013" larger. Hey Made in OC, if you have several sets of Hardrace bushings laying around, could you tell me what is the diameter of the front LCA to shock bushing for DC2? And whether you have another bushing for a different car that's barely larger?
Anyway, this still doesn't explain the poor sheet metal work on the compliance bushings.
PS: Are you willing to sell just the front bushings?
Old Jan 21, 2009 | 11:33 PM
PM me with what specific bushings and car model you need and ill look into it.
Old Jan 21, 2009 | 11:53 PM
beanbag's Avatar
Originally Posted by beanbag
... what is the diameter of the front LCA to shock bushing for DC2?
Old Jan 23, 2009 | 02:19 AM
an2ny888's Avatar
only issue i have with my hardrace bushings is some of them went very slightly out of round when i pressed them in, namely the rear compensator arm bushings
Old Jan 25, 2009 | 09:51 PM
4door hobo's Avatar
I did all 28 bushings or what ever two weeks ago with a cheap home made press, it took all day but they fit in perfect. I used the 94-01 integra kit for my eg 4door and they went in nice and snug. Once i got the all the random sockets and pipe need to press, it went kinda fast. I did research a bunch of the top companies for weeks and am glad I got the hardrace bushings!
Old Jan 26, 2009 | 05:31 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
What sort of home-made press did you use? Something that looks like a C-clamp? Or did you use a bench vise or similar?
Old Jan 26, 2009 | 12:29 PM
maxogsr's Avatar
Had no issue with mine either... Went in there perfectly... But I can imagine the poor guy...loll!! Not funny at all when all bushings are wrong...must have sware like hell!
Old Jan 26, 2009 | 12:49 PM
beanbag's Avatar
Looks like the earlier batches were defective, then
hybrid90
Jan 22, 2008 03:31 PM
manyakiexpi
Mar 23, 2006 05:12 AM
jsrusse11
Nov 7, 2005 07:58 AM
johnzm
Nov 16, 2002 04:11 PM
charjacq
May 29, 2002 12:37 PM
