94 ls, rebuilt head, headgasket, ect... cranks but no start (SEARCHED)
Old Jan 18, 2009 | 05:29 PM
1992blueGSR's Avatar
Default 94 ls, rebuilt head, headgasket, ect... cranks but no start (SEARCHED)
first off it my buddys car
94 ls B18b
just got all the head work done, valve seals, latches adjusted, 3 angle valve job, port and polish.
while it was off we did the head gasket, and most of the rest of the gaskets on the top end.
got everything back on today, torqued to correct specs, timed it, ect..... all the little stuff
it will crank all day long but it wont fire to save its life
it has spark, all the way to the plugs
has fuel, correct pressure, can smell it on the plugs, so it is getting all the way to the piston
it sounds like it has compression, you can hear it
we have checked the timing, double checked, and triple checked
its right
we even tried to put the dizzy on 180 out, but still nothing.....
does anyone have any ideas on what to check next....
weve checked all the sensors and they are all in the right spot, and i dont think its the ecu since were getting fuel and spark
my first instinct was the timing but its all right
ANYONE HAVE ANY IDEAS??????
thanks in advance
Old Jan 18, 2009 | 07:28 PM
dRoPpEd lS's Avatar
Default Re: 94 ls, rebuilt head, headgasket, ect... cranks but no start (SEARCHED)
check the coil in the distrubtor i just had the same problem
raverx3m
10
Oct 14, 2013 04:49 PM
S_F
34
Nov 22, 2012 10:54 AM
ej1b18b1
Mar 2, 2009 07:09 AM
wickedplastikman
Jan 18, 2005 10:15 AM
