Will JRSC off of d16y8 work with a d16a6?
I found a jackson racing supercharger for sale that the guy says is off of a d16y8. My question is will it work with my d16a6? I know the manifold will bolt up fine since they are the same bolt pattern/intake flange. What i'm more concerned about is whether or not the belt will line up, if the brackets work, etc.
SOme pics are gone but a y8 manifold has a slight offset to it compared to the Z6 and A6 manifold to clear the Master Cylinder Booster in that civic.
https://honda-tech.com/forums/showth...564&highlight=
intake manifold is spaced differently your pulleys will be off, do a search in the forced induction section some have been able to make it work with shims, but it may be easier to get a z6 one if you havent bought it yet...
....now another question.I`m planning of getting a Y8 JRSC, already have the zcspeed plate adapter.....and bolt everything on a ZC (DOHC) engine.Does anybody have a clue if they will align?Anybody has the same setup?I need to confirm this before I buy it
Thanks
Thanks
clubef9
Oct 11, 2008 08:25 PM
DsMWookie
Sep 2, 2003 10:44 PM
