Idle/IACV issue
88/89 crx hf - ba8a1 swap
if I plug in my iacv/eacv my idle goes up to about 1500 RPM and bounces about 75-100 RPM if that...I unplug the IACV and I idle at about 6-700 RPM with no flutter or anything...
I have redone vacuum lines - checked for vacuum leaks but can not find one...screwed the plunger and **** back in the FITV (fast idle valve). I even swapped the IACV with a shelf spare I had in the garage off a b16
can anyone confirm (preferably with images) pinout for iacv to wiring harness or ecu - I know on ECU it should be a-11 but I just want to be sure...
or if anyone has any ideas as to what I could be missing
My mechanic discovered a faulty, torn intake manifold gasket on my '89 Hf. I replaced the EGR valve while I was at it. Work still in progress, I'll let you know how it goes.
Isn't it a9 it should be a green/ white wire.
allmotorlsvtecrx
Dec 17, 2004 10:02 AM
DsMWookie
May 25, 2004 02:24 PM
