Boosting a prelude. Running with 1 fan vs aftermarket
Old Jan 18, 2009 | 01:26 PM
es_squared's Avatar
Default Boosting a prelude. Running with 1 fan vs aftermarket
Boosting the prelude soon and was fitting the turbo on, and noticed that Ill either need to run with one fan, or, get some after market slim ones. Any suggestions/recommendations? Anyone tried running with one fan while boosted?
Old Jan 19, 2009 | 09:56 AM
PrecisionH23a's Avatar
Default Re: Boosting a prelude. Running with 1 fan vs aftermarket
If you are keeping AC, you will need 2 fans. If you are keeping the dual size radiator, I would recommend running the SPAL 13" fan. We just recently finished a customers custom turbo set-up and it's possible to fit a SPAL 11" puller fan on the condensor side. It's a pain in the *** to install but it works. You can also get away with running the 1/2 size civic KOYO radiator.
Old Jan 21, 2009 | 09:58 AM
es_squared's Avatar
I've got no AC but thanks for the info man
Old Jan 22, 2009 | 05:24 PM
McLude2nR's Avatar
I ran one fan w/ full stock radiator and no A/C. I was fine on temps at all times on my setup.
Old Jan 22, 2009 | 06:18 PM
es_squared's Avatar
Thanks, good to know that it'll work fine
Old Jan 24, 2009 | 06:03 PM
preludestud11's Avatar
I ran one slim fan on mine. I kept ac, and never had a problem.
Old Jan 24, 2009 | 07:30 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
13in spal fan the best option you have and will work
Old Jan 24, 2009 | 10:09 PM
es_squared's Avatar
Rad, thanks again guys
Old Jan 24, 2009 | 10:47 PM
streetracer6rpt's Avatar
Civic rad, single fan
milkypros
Aug 10, 2011 03:17 PM
slimsclub
Mar 30, 2011 05:15 PM
Mavlude
Mar 22, 2011 12:57 PM
integraGSR213
Jan 26, 2004 05:34 PM
420aNT
Oct 26, 2002 03:12 PM
