idle problems
Old Jan 18, 2009 | 12:36 PM
gsrpowercrx's Avatar
Default idle problems
i have a gsr its stilll obd0 it idleall diffrent all the time normally wants to stall . when i rev it and let go the gas it stalls or all most stalls i did the idle set screw settin it for ran good for like 20 min idle really good rev up good thought i fixed it then i reved it again and the problems started again i changed iacv didnt do nuttin there no engine codes i thought maybe it was cuz i was runnin a chipped pr3 but i changed to a virgin pw0 and same thing timing is good and some times it will flood it but not all the time plz help some body help
Old Jan 18, 2009 | 12:39 PM
hondasaurusrex's Avatar
Default Re: idle problems
check the dizzy cap/rotor...if the rotor is loose it'll act that way...
is it throwing any codes?
Old Jan 18, 2009 | 02:51 PM
no codes at all on either ecu
z6hatchboy
Feb 7, 2008 01:28 PM
jdmcrx90
Jul 26, 2006 04:34 PM
96greyek
11
Mar 26, 2006 06:38 PM
EK Josh
29
Apr 11, 2005 11:05 AM
