94 lx jolt
hey when i an driving my car sometimes in certain gears when i barely tough the gas it will do a little jolt like its not getting gas but then it will take off.....i really cant figure it out and i was wondering if anyone else has had this problem and what they came up with. it also will idle at about 500 while its just sitting there....
When was the last time you did any maintenance to your ignition system (spark plugs, wires, cap and rotor)? If your ignition system hasnt had any attention lately that might be the cause of your problem. Worn out ignition parts tend to cause random misfires (or "jolts" as you called it) usually at high load / low RPM situations.
Try replacing your spark plugs, wires, cap and rotor (spark plugs 4 @ $2.00 each, cap and rotor $25, wires $30-40). Also make sure your air filter is in good condition. If a fuel filter was clogged up you might also notice a misfire in a high load (throttle) condition, but more noticably at higher RPM's.
Their may be other problems as well (such as a worn out or unplugged O2 sensor, or other engine sensors), but always start with the basic maintenance items.
yeah thats whats i was kind of thinking too but i wanted to get an opinion of someone else....i just got this car about a week ago and the previous owener said it did the same thing...the air filter and the fuel filter is exactly what i was thinking...so ill prolly check that out! THANKS!
Yep- I just got a '95 accord EX a littile while ago and it had a really bad hesitation, so I replaced all the ignition components this weekend and now it runs nice and smooth throughout all throttle and RPM ranges. I would still suspect the ignition components first over the fuel/air filters tho- but anyway just replace the ignition, fuel filter, and air filters and you should be good to go!
91-integra
Jan 28, 2020 10:36 AM
Tuesdaynightfever
May 4, 2008 10:01 AM
model x
Sep 13, 2002 12:51 PM
