just a short question
sure will. hang onto your stock one, though. if you plug in the spoon cluster, and it doesn't work properly, you may have to swich in the green film from your stock cluster. some year differences had electrical differences, too. i'd imagine that that would be a direct working piece, though
It is not complete plug and play. Instead of swapping the green films, I highly suggest swapping the gauges into your stock housing. Reason being is because the ABS wire is on the main harness for 94-97 Integras (or the 96 spec Spoon cluster) while the ABS wire is on the SRS harness for 98-01 Integras (your Integra). So, your ABS light will go on (if there is one on the Spoon cluster).
I've done this....Just take your time when you switch the film...there are like 10 to 15 screws that hold it in place. And once you get it in, you'll see that the fasten seal belt marker and the door open maker are switched. Other than that, everything works fine
Mugen_DC2R
Jan 12, 2007 08:11 AM
Black R
Apr 30, 2005 10:03 AM
