Nned help!! Surging idle!!
Old Jan 18, 2009 | 08:12 AM
NVMYDC's Avatar
Default Nned help!! Surging idle!!
okay..recently i had an 00 si tranny installed on my 94 b18c1. everythign was going fine, until i saw that i had a radiator leak..so i uninstalled my radiator and installed a new one, cranked her up and now surging idle like 1500rpm to 3k, i took it to a very good friend of mines that works at the acura and honda's specialist and he told me to check the vaccume lines throttle cable throttle plate etc...check all those and still no answers, i cleaned the idle control screw and loosed my throttle cable (it was a bit too tight) and it brougt my idle down to 1k to 2k...this all happend after i uninstalled my radiator, could it be air in my coolant system or something else? please help!!
Old Jan 19, 2009 | 08:44 AM
NVMYDC's Avatar
Default Re: Nned help!! Surging idle!!
any body?
Old Jan 19, 2009 | 09:11 AM
Jimmy's Avatar
Global Moderator
Yes it could be air in your coolant system.. Bleed your coolant..
Remove your radiator cap with the engine cold.. start the engine.. squeeze the raditator hose and burp the air pockets/bubbles out.. let the car idle
Reinstall radiator cap
Did you even try searching?
Old Jan 19, 2009 | 12:07 PM
NVMYDC's Avatar
i've searched far and wide no results....i cleaned my fitv,iacv,replaced the iacv, replaced all vaccume lines, bled coolent today, cleaned throttle body and throttle plate,cleaned idle control screw, had my throttle cable adj. accordingly, and the surging idle wasnt as bad but is still there
Old Jan 22, 2009 | 02:20 AM
davidc's Avatar
If you've cleaned the IACV and the FITV and you still have the surge, then one of them needs to be replaced.
I don't think there is an exact way to tell which one it is, but the local Acura parts dealer told me that he sells IACV two to one vs. the FITV.
But, the FITV is much less expensive, and it's returnable because it's not considered and electrical part. So, I'd try that first.
I'm going through the exact same thing right now...but after about 3-4 months of it, the surging stiopped, now I just have an excessively high idle of 3-4000rpm! Put my finger on the lower hole in the TB and there lots of suction. When I cover it the idle returns to normal, so I know it's my FITV.
Old Jan 22, 2009 | 02:37 AM
sp00ledbseries's Avatar
see if one of your friends has one they will let you swap on to your car to check things b4 buying it. more than likely it is your iacv
Ef4doorwagon
17
Apr 6, 2014 03:31 PM
Skyhigh07
Jan 15, 2009 11:48 AM
blakacintegra
Dec 5, 2006 07:46 PM
projectxspeed
Apr 13, 2005 10:17 AM
SeaBass
Dec 18, 2003 03:27 PM
