96 Accord LX Oil Drain Plug Torque Setting?
Old Jan 18, 2009 | 07:39 AM
Cactus's Avatar
Default 96 Accord LX Oil Drain Plug Torque Setting?
So I can't get my drain plug to stop dripping and I don't want to over-tighten it so what is the recommended torque setting? Tried a new plug, always a new washer at oil change, and it was never over-tightened to warp the metal.
Old Jan 18, 2009 | 08:04 AM
The-Kid's Avatar
Default Re: 96 Accord LX Oil Drain Plug Torque Setting?
It says 33ft lbs.
You sure it's from your drain plug? check the oil pan gasket, who knows? Mine was leaking all over the place.
Old Jan 18, 2009 | 03:07 PM
Cactus's Avatar
Originally Posted by The-Kid
It says 33ft lbs.
Yeah it is the plug....thanks for the info.
Old Jan 18, 2009 | 05:20 PM
alkoholikwun's Avatar
try a thin rubber washer and/or use some honda bond for the bolt threads.
Old Jan 18, 2009 | 06:02 PM
ricebike's Avatar
or get a washer that has an outer ring of metal and an inner ring of rubber...
any autoparts store has these in their oil drain plug/gasket section, predominately made by motormite/ dorman
1/2" is the size of the gasket, i believe
Old Jan 20, 2009 | 06:17 PM
masterkill455's Avatar
next oil change, spray off the plug with brake cleaner and wipe off the pan and wipe out the threads and lightly coat with permatex 2B gasket sealant, the thick brown gooey crap. that can fix almost any leak. I guess if you really wanna be creative, maybe it was over tightened and actually cracked the bottom of the pan next to the hole
rdean
Honda Civic (2001 - 2005)
Mar 26, 2011 01:09 PM
elmalouno
Apr 26, 2009 07:42 AM
RAYThOM
Feb 24, 2007 11:38 AM
justinCO
Oct 7, 2002 02:37 PM
