Prelude VS Prelude Si
Old Aug 6, 2002 | 03:13 PM
MentaL's Avatar
Default Prelude VS Prelude Si
Hey Im planning to get a 4th gen prelude soon
My question is how much faster are the Si preludes the the regluar i know they are 30 more hp, i dont wanna go hard core speed and stuff but i want the power and wanna be able to go pretty fast. Is it a big noticable difference or just a little fast or what. Thanks
Old Aug 6, 2002 | 03:23 PM
satan_srv's Avatar
Default Re: Prelude VS Prelude Si (MentaL)
S = 135
Si = 160
VTEC = 190
Which models are you referring to?
Old Aug 6, 2002 | 05:14 PM
MentaL's Avatar
what do you mean
Old Aug 6, 2002 | 08:27 PM
armharm's Avatar
get the Si... no doubt.... the price difference between the 135HP and the 160HP is too little to be significant..
Old Aug 6, 2002 | 08:28 PM
Unreasonable's Avatar
Compare the 4th Generation Ludes here:
http://www.hondaprelude.com/resource.../usdmspecs.asp
The Prelude S is SOHC, the Si and VTEC ones are DOHC. If you want to modify it then get an Si or VTEC. Modifying the S is a waste of time - You would end up putting more money into it making it faster than just buying an already faster Si or VTEC. This applies to the US 92-96 models (93-96 for VTEC). 97 and up are all VTEC. Between an S and Si? Noticeable difference. If you modify it then BIG noticeable difference.
Old Aug 6, 2002 | 08:52 PM
PrecisionH23a's Avatar
Default Re: Prelude VS Prelude Si (preylude)
The S is a waste of money, its like having a sohc d motor in hatchback plus about 500lbs. The Si is bad ***, the vtec is bad ***. Stay away from the S and get the Si or Vtec depending on your budget...
Old Aug 10, 2002 | 05:10 AM
PapaRoach736's Avatar
I used to own a 93 si and now i own a 96 vtec and the difference in power is a definite improvement. Of course my si was a piece. I say go with the vtec if u can get it.
Old Aug 10, 2002 | 07:00 AM
ViZ's Avatar
ViZ
Default Re: Prelude VS Prelude Si (PapaRoach96Vtec)
go with the VTEC even if you have to hunt for longer its worth it becase you will be wanting the engine later anyway... i did and i spent more money just to get it... and i love the vtec motor
RogueStatusVT3C
Nov 29, 2009 01:04 PM
nissan480
Dec 11, 2007 09:45 PM
hagrid
Jan 27, 2003 01:23 PM
lodown414
Jun 1, 2002 12:51 PM
