HELP!! B16 swap info needed
i know uv prob had this many times before but i cant seem to find everything i need to know and i wanna do this swap with as little problems as possible.
iv got a 93 civic lsi with the 1.5 engine, iv got a b16 engine out of a 93 vti, i need to know everything to do the swap.
so far iv got the b16 engine, engine mounts, rear mount, gear linkage, engine wiring loom, ecu
will the wiring loom on the b16 engine plug straight into my existin wiring loom?
will the ecu plug straight in?
will my existin driveshafts fit?
is there anything else i need to know?
any help very much apreciated
jon
jon
Try searching, And just off the top of my head your gonna need axles, your stock wireing harness will work and yeah your ECU will plug in but your gonna need run i think its two wires into your ECU for VTEC to work.
iv tried searchin but im crap wiv searchin, i dunno if im puttin in the wrong key words or wha. iv just tried searchin about the wires u need to run for vtec, i find a few threads sayin u need to do it but cant find any on how to?
i was hopin for a link or sumin to a thread to point me in the right direction.
aint there a thread where sum 1 has done the swap an put a list of evrything they used instead of it all bein spread over a website?
thanx for yur help.
i jus wanna make a list of everything i need cos i wanna get this swap done in a day if i can so my car aint off the road long
thanx for yur help.
You need a b series trans, y21 is the b16 trans but any hydro b series will work along with b series axles and half shaft. You need to run 2 vtec wires and a ground to the correct pins on the ecu.
fiktion91
Jun 7, 2012 02:39 PM
joelmatt89
Jan 27, 2009 08:12 PM
nexgen91
Mar 7, 2006 07:27 AM
