What intake CAN I use?
Old Jan 17, 2009 | 06:50 PM
soodominican's Avatar
Default What intake CAN I use?
I have a 96 b18b with the stock intake tube from the b18b and an STi Injen short ram. The tubing hits the battery and the intake is a tight fit. What intake set-ups do you guys have? Any pics? Thanks
Old Jan 17, 2009 | 07:07 PM
Radim's Avatar
Default Re: What intake CAN I use?
You can just relocate your battery; if you don't want to do that AEM has a hybrid line of intakes for engine swap.
You are saving a lot of you just relocate your battery too.
Old Jan 17, 2009 | 07:13 PM
BLU CIVIC's Avatar
Track Advocate
i just used a 88-91 Civic ebay intake
Old Jan 17, 2009 | 09:24 PM
I'm going with that second option, I don't have the money to relocate the battery and I really don't have 250 for the hybrid intake.
Old Jan 17, 2009 | 09:57 PM
89s1's Avatar
Be sure to have a terminal cover on the positive battery terminal so it never touches the intake as shown in the pic.
Old Jan 18, 2009 | 01:21 AM
D16SiHatch's Avatar
or better yet do what i did and flip your battery around so that the positive terminal is nowhere near the intake tube
Old Jan 18, 2009 | 10:26 AM
BLU CIVIC's Avatar
Track Advocate
i just put a pen top on top of the post...although turning the battery around seems like a good idea too
Old Jan 18, 2009 | 10:41 AM
Will the connections reach out there? Sounds like a very good idea though. What if the intake touches the ground terminal? It'll still end up grounding itself on the intake if it touches won't it?
Old Jan 18, 2009 | 05:04 PM
D16SiHatch's Avatar
huh? no lol. the positive terminal arcs to the intake pipe because its completing a circuit. electricity flows from the negative terminal, to the chassis, to the intake pipe, and then right into the positive terminal. so basically like laying a wire across both batt. terminals. If the battery negative is against the pipe, nothing is going to happen, because they are both grounds and is no circuit can be completed.
Old Jan 18, 2009 | 06:16 PM
OOOOh, ok TY =]
rjmq06
12
Dec 11, 2009 01:49 PM
i-VTEC_DOHC
Honda Civic (2006 - 2015)
30
Oct 28, 2009 05:40 AM
MG-EP3
22
Sep 1, 2009 10:00 AM
oldschoolfreak
Oct 27, 2004 07:13 PM
SiZ
28
Sep 13, 2002 11:48 PM
