big spline, small spline...
cant find any gospel as to if i have the small spline cable trans or the basic 92-01 spline.
i have a cable Y1 b16 tranny, LSD, i dont have another tranny to compare it too and i dont want to order the wrong clutch. i cant find any info on how to check if its the small spline or the big spline tranny on here or google.
i found some info saying cable b16 trannies are small spline but then i see some saying the lsd ones were big...
the early year cables are small, the later year cables are big, they are different spline counts and measurements, they have got to be on h-t somewhere, i cant remember them off hand.
measure it
i was told by ACT that the 90-91 is 1" and the 92-93 is 1 3/32"
and i think 1" is 25.4mm.
as far as the count, its still up in the air, some guys say small is 24 and big is 26, others say that all usdm b-series trannys have the same count just diff size. either way measure the shaft and count the teeth.
A Y-1 transmissions is 90-91
So when they ask what kind of car the clutch is for..say this:
1990 Integra
Good luck!
92-93 cable transmissions have a different spline...just like the 94-01 Integras.
1990 Integra
Good luck!
did the lsd trannies have the big spline? i assume no since its still 90-91.
also i have a 92-93 act hdss pressure plate and 92-93 flywheel can i use my 92-93 pressure plate and flywheel and just buy a 90-91 clutch disc?
VtecKiDD
10
Jul 31, 2004 08:45 PM
