b-series crx crank pulley
This is my second b crx. I had an lsvtec and now an ls. I didn't seem to have this problem with my old crx and it was pretty low, actually lower, but the crank pulley is scraping the front radius bar when the suspension is compressed. What is a solution to this? Different mounts? Different crank pulley? Is this a common problem with the b series crx's? I am not running a/c or p/s so is there a crank pulley available with those pulleys deleted?
Thanks in advance
Thanks in advance
ya ive got an n1 pulley and no prob had a b16 and a gsr both in my crx although ive got an aftermarket crossmember, but as far as the pulley goes this is an oem honda part and will not hurt your crank, or throw it off balance.. as the other brands that offer aluminum ones will not properly balance the motor
i bought the ctr n1 pulley to correct this exact issue. you can either go that route or if it'd make you feel safer, take your stock pulley to a machine shop and have them machine off the a/c and p/s ribs, that way you can retain the internal damper.
my roomate has a 90 crx si with an ls and CHEAP mounts..his rubbed also, we've hadnumerous swaps and never had a problem, until we gave these mounts a try. new mounts and it fixed his problem...
i had the same problem and it ended up just being the pulley. it was a 00 ls motor so i swapped the pulley with a old DA pulley and didnt have any problems.
just like the guy who used the DA pully from the b18A1 its works just fine on my b18b1 block.....clears the arm....or could i suggest aftermarket tracion bars or front crossmember
b18_crx
19
May 17, 2005 11:48 AM
