Koni/Ground Control Installation(did a search)
Old Jan 17, 2009 | 08:39 AM
xileap2's Avatar
Default Koni/Ground Control Installation(did a search)
Here it goes im about to install the Koni/Ground Control coilovers with tophats. question is would i need to use the OEM bumpstops and cut them in half, i know its a dumb questoin, but a friend of mine informed me that i didnt need to use the bumpstops if i have tophats. Any help greatly appreciated.
Old Jan 17, 2009 | 11:58 AM
xci_ed6's Avatar
Default Re: Koni/Ground Control Installation(did a search)
contact ground control.
Old Jan 17, 2009 | 12:13 PM
01-0041's Avatar
When you received your Ground Control hats did they supply bump stops?
Old Jan 17, 2009 | 12:24 PM
iheartteal's Avatar
the top hats should of came with new bumpstops
Old Jan 17, 2009 | 03:53 PM
xileap2's Avatar
no they didnt. so i have to go out and order some right?
Old Jan 17, 2009 | 04:12 PM
hushypushy's Avatar
You don't need bumpstops. Just put the Konis on the highest stiffness if you're going slammed and you'll be fine.
Old Jan 17, 2009 | 04:21 PM
01-0041's Avatar
That sounds like a great idea... :-(
Old Jan 17, 2009 | 05:36 PM
m_shake's Avatar
email gc, i had same type of problem they forgot the stops, so they sent me some for free. gl what spring rates you get?
Old Jan 17, 2009 | 07:15 PM
xileap2's Avatar
i cant keep waiting on the bumpstops so im just gonna order the OEM and cut in half. Im gonna run Koni with Ground Control 500f and 550r
kingK
Mar 25, 2015 03:51 PM
mish__
Suspension & Brakes
Aug 27, 2011 03:41 AM
Daniel_san
Aug 17, 2004 12:26 PM
Isaac
Apr 19, 2002 09:08 AM
