Noop
sup everyone? new to honda's hardly know **** about them. but not new to the car game.
have a 91 Crx Si and the gauge cluster's backlights (to see them at night) doesnt work. the turn signal and dummy lights work in the cluster yet the backlight doesnt light up. also the dome light does not work. i replaced with a new bulb and checked all fuses and nothing. any ideas?
Did you replace the cluster bulbs too cause thats more than likely the issue.
As far as the dome light, Id pull it down and check it with a test light. The White/Blue wire should have power(The other 2 are grounds). If not, see if your clock or your trunk lights work. If they do, you have an issue in the harness going into the roof. If not, check fuse 12, its a 15 amp.
Hope that helps any
Hope that helps any
tearinox
Oct 19, 2006 06:49 PM
integracura
Nov 28, 2005 05:20 PM
