TPS sensor volt test
Old Jan 16, 2009 | 10:59 PM
dohcem1's Avatar
Default TPS sensor volt test
How exactly do you test for the volt on the tps? does the car has to be on ? i dont exactly get where on the sensor can you test for the volt? thanks.
Old Jan 18, 2009 | 12:14 AM
dohcem1's Avatar
Default Re: TPS sensor volt test
please advise?
Old Jan 20, 2009 | 01:05 PM
chicows18's Avatar
i believe its the red wire that goes to the TPS. Car does not have to be on but ignition does. And I believe it should read as close to 0.5 v as possible. If its over, it bad.
Old Jan 20, 2009 | 08:05 PM
dohcem1's Avatar
Well yeh I know about the .5 v and stuff I just meant how do I physically test for it. SO i basically have to strip the red wire that goes to the TPS sensor and put a multimeter and read the voltage?
Old Feb 2, 2009 | 11:55 PM
SINISTR's Avatar
do you have a multimeter?
Old Feb 3, 2009 | 01:25 PM
dohcem1's Avatar
yes i do, I just don't know where I could physically test the volt...
Old Feb 3, 2009 | 05:45 PM
LA_HONDAS's Avatar
stick it in the seals
Old Feb 3, 2009 | 10:02 PM
dohcem1's Avatar
...seals? can you clarify that? Sorry for being such a newb but i really do not know. Thanks
Old Feb 3, 2009 | 11:42 PM
NUISANCE's Avatar
Here dude
http://www.clubintegra.com/board/showthread.php?t=21792
Old Feb 4, 2009 | 07:55 AM
dohcem1's Avatar
Wow PERFECT PERFECT thank you for the link. Exactly what I was looking for. One last question, the OP of that thread saids to set it at .5 volt (and so did chicows18 earlier post), but i thought I saw somewhere that saids set to .45 volts is best? well does it even make a difference? Just curious. Thanks
Old Feb 5, 2009 | 03:31 AM
NUISANCE's Avatar
I set it at .5, not sure if it makes a difference but seems to be what it is supposed to be at.
Old Feb 5, 2009 | 10:29 PM
dohcem1's Avatar
ok thanks
Old Jan 22, 2010 | 01:11 PM
SniperRCivic's Avatar
in my haynes book it says with the engine off and the throttle valve fully closed it should read 0.5 and with the throttle fully opened it should read 4.5
jerryliedtke
Sep 21, 2014 09:25 AM
chrisfromsrq
Aug 4, 2009 04:55 PM
MJT805
Jun 12, 2009 11:05 AM
mickey513
Apr 16, 2003 05:35 AM
Bo0sT_JuNkY
Mar 1, 2003 07:49 PM
