HELP Lug nut and bolt spinning together.
91 honda accord lug nut and stud spinning together. The nut moving but not getting any looser how do i get it off without messing up my rim?
You can try drilling out the lug, similar to what this guy did with his Jeep:
http://www.greatlakes4x4.com/showthread.php?t=112066
No need to cut the tire and wheel off, just drill out the lug. If that doesn't work, use a dremel to cut into the nut and then chisel the remaining off if need be. If your wheels are pristine, I would tape all around the lug so that nothing slips and scratches the wheel.
An alloy rim makes it tough, most often being countersunk.
Hopefully, the stud has not started turning with the nut (as you've related) cuz that would indicate you'd also need a hub assembly since the lug stud stripped out.
http://www.hondaautomotiveparts.com/auto/jsp/mws/prddisplay.jsp?inputstate=5&catcgry1=ACCORD&catcgr y2=1991&catcgry3=4DR+LX&catcgry4=KA4AT&catcgry5=FR ONT+BRAKE+%28AKEBONO%29
P
well i had the same prob. my friend took about four 3/8 inch extensions. and a 19mm socket. put it on the lug and bent it back and forth till the lug broke. it didnt harm anything and now i can take tire off
