B-series turbo kit cheap!! Easy 250-300 hp!
UP FOR SALE IS A SEMI COMPLETE TURBO KIT FOR A HONDA B-series ENGINE. THIS KIT COMES WITH EVERYTHING PICTURED. YOU WILL GET A FRESHLY REBUILT TD05H 14B TURBO CHARGER WITH THE EXHAUST HOUSING(PARTIAL DOWNPIPE WITH O2 BUNG) , THE INTERNAL WASTEGATE HAS BEEN WELDED CLOSED, THE TURBO HAS NOT BEEN USED AFTER REBUILD. NEW B-SERIES TURBO EXHAUST MANIFOLD WITH USED EXTERNAL 38MM WASTEGATE, 8 PSI SPRING IN THE WASTEGATE. AUTO METER 4301 BOOST GAUGE NEW IN THE BOX, HIGH VOLUME FUEL PUMP BRAND NEW, NEW OIL FEED AND RETURN LINES, DSM 450CC INJECTORS AND USED OBX FMU. THIS TURBO SET-UP WILL BE PERFECT FOR A STOCK B-SERIES ENGINE. USING A SMALL TURBO WILL ALLOW A QUICK SPOOL AND 8PSI WILL BE PLENTY TO PUT YOU BACK IN YOUR SEAT. THIS SYSTEM IS CAPABLE OF 250-300 HP WITH THE CORRECT TUNE. Also the turbo inlet housing has been ported for more air flow!! PLEASE FEEL FREE TO ASK ?'S
IAM ASKING $500 obo...will ship!
dumppp gook
Northern California (Sales)
Jun 30, 2014 11:02 AM
JDmspoon22
Jan 16, 2008 11:52 AM
KeyserSoze
Apr 5, 2006 03:31 AM
