Scan tool on my ED7?
Old Jan 16, 2009 | 10:30 PM
soodominican's Avatar
Default Scan tool on my ED7?
I'm having some issues with my car idling ridiculously low and I can't figure it out, adjusting the idle with the IACV isn't doing ****. I suck in more air like I should but idle stays exactly the same. I have an obd2 B18B with a obd1 pr4, can I hook up a scan tool to see what my crank sensor is telling my ECU? I have a feeling it's sending the wrong info and that's why I idle so low, stall when I let off the throttle in reverse and stall when I brake moderately hard to a stop. Thanks
Old Jan 17, 2009 | 08:35 AM
crx_si-r's Avatar
Default Re: Scan tool on my ED7?
No you cannot hook up a scan tool unless you have a diagnostic port installed. And the only way you would have installed would be if you did a full obd2 conversion and I'm going to assume that you didn't do that because it's a very difficult thing to do.
Old Jan 17, 2009 | 01:25 PM
Thanks, I guess I'll have to find some other way to resolve my idling issues
Bangher4$
Mar 23, 2009 08:17 AM
soodominican
Jan 16, 2009 09:32 AM
pork
Sep 24, 2007 09:46 AM
b_serious
Nov 16, 2005 09:05 AM
StinkyTofu
Apr 6, 2003 09:31 AM
