Swaping the B16 for the H2B setup.. what do i need now
I already have a B16A with the Y1 tranny and want the H22 now but do i need to change anything else to drop it in, i now i need that H2B kit to make everything align but what else.
cool but do i need to send my wiring harness and the h22 one to rywire so it will plug and play or is everything there, im just not so sure how much different the wiring is on the h22 than the one already installed on the b16 and converted to obd1
No, you wont need new mounts. The qsd kit is designed to use all of your existing b-series parts: mounts, axles, shift linkage etc will not need to be changed. You pretty much just need the h2b kit and an h22 longblock plus some small oddball stuff. You should use the wire-harness you already have, just extend the alt wires. Check out the hybrid forum for tons of h2b info.
PURPLETERROR aka BIGMATT
26
Apr 2, 2006 04:06 PM
