fast idle screw/Does this happen to anyone else.
Old Jan 16, 2009 | 07:37 PM
thermostate82's Avatar
Default fast idle screw/Does this happen to anyone else.
So I I am looking for a way to get just the fast idle screw for the throttle on a 97 base. I have looked all over cant find just the screw. I called honda and they said i have to buy the whole throttle which is 700$ So if anyone has it Let me know how I can get another on.the selt belts on my lude always get in the way of the door it was like that on my 91 lude to,also when I go to hit my defrost button on the climate controls the button lites up does that happen to anyone here?
Old Jan 16, 2009 | 09:40 PM
gstrudler's Avatar
Default Re: fast idle screw/Does this happen to anyone else.
please make separate posts for separate questions.
1) i have never heard of a replacement just for the idle set screw. you will probably have to get one machined or go pick up a new tb from a junkyard
2) i thought i remember hearing you can get your seatbelt replaced under warranty if a certain amount of slack exists upon retraction
3) isn't the light supposed to go on when you choose something on the climate control? what is actually the problem?
Old Jan 17, 2009 | 06:12 AM
If I hit the defrost option while the heat is on then the ac button lights up and stays on untill I hit the ac button again and turn it off.
Old Jan 17, 2009 | 06:27 AM
A Blue Lude's Avatar
That's normal.
If your throttle screw wasn't in place I'd think you would have big idle issues.
Old Jan 17, 2009 | 06:32 AM
its not I had to find a really long screw with a nut to keep it from falling out. Kind of, looks like the screw for the outlet box you put in a wall and it is sitting on a nut so that the car doesnt idle really low but it is still a little low on the idle because the lights dim if I let it idle.
Old Jan 17, 2009 | 09:14 AM
zsudz922's Avatar
this is true. i went to the dealer and asked them because mine wasnt retracting very well. still havent done anything about it though.hah
da9crxsi
Jun 4, 2012 09:52 AM
nghtshd88
Apr 7, 2011 08:18 PM
mad21kid
Feb 18, 2008 12:52 PM
gutted-dx
Dec 18, 2005 09:08 PM
oi-punx
Nov 14, 2002 02:01 PM
