Gear grinding
Old Jan 16, 2009 | 07:35 PM
SoCalian_SD's Avatar
Default Gear grinding
I test drove a 2000 prelude the other night and when ever i put it in to 5th gear there would be a very slite grind, the owner said i wasnt depressing the clutch all of the way. He said that 5th gear is very tempermental. Does this mean the tranny is going bad, I.e synchros??
The car has 150k on it.
Old Jan 17, 2009 | 02:04 PM
RomPirate's Avatar
Default Re: Gear grinding
5th gear grind is a fairly common problem on 5th gens. It requires dropping the transmission and replacing a shift fork or something.
Make the owner drive it and show you how to not grind it before you even consider buying. (which I assume you are since your new)
Old Jan 17, 2009 | 05:38 PM
Yea im not buying it anyway... Thanks for the reply tho.
Old Jan 18, 2009 | 07:43 AM
street_ride14's Avatar
Don't rev the hell out of it in 4th, and you won't grind into 5th. This is very common for Preludes exp mid to high mileage ones.
d16efsedan
16
Nov 29, 2016 09:35 PM
94jdmlude
Dec 30, 2008 02:38 PM
MTR.18
Mar 27, 2005 08:11 AM
missinghubcabs
Jun 25, 2003 03:41 PM
