Need help car will not start or turn over
Old Jan 16, 2009 | 01:49 PM
Nova77's Avatar
Default Need help car will not start or turn over
I have a new batt and a starter and it is surpose to be a 89 Civic with a ZC motor swap. I dont know about civic so i need a lot of help what can it be
Old Jan 16, 2009 | 01:54 PM
Perfectionist's Avatar
Default Re: Need help car will not start or turn over
Could be anything, based on your lack of description of the symptoms.
Old Jan 16, 2009 | 09:02 PM
almostjdmeg's Avatar
Check the ignition fuse under the hood. It should be 50Amps. If it is blown you will here a loud click when you turn the key to try and start the car.
Old Jan 28, 2009 | 04:50 PM
runvegas's Avatar
your valves could be open, check the lash.
Old Jan 28, 2009 | 04:58 PM
93formula's Avatar
check all grounds
japanstar_ef9
Sep 1, 2008 12:28 PM
Eg6_rAcEr
14
Nov 8, 2007 12:34 PM
quintb2000
15
Jul 25, 2007 08:29 PM
CIVICRicerBoy
Apr 30, 2007 07:12 PM
boostedcivichatchbacksi
Sep 8, 2004 08:19 PM
