91 da gs to 89 crx hf
Old Jan 16, 2009 | 11:37 AM
crxhondata's Avatar
Default 91 da gs to 89 crx hf
hello honda's lovers friend off my he selling . a da 91 complete motor is blow but the trans is good can use the trans.axles,motor mounts.engine harness, i mean every thing will just fit on a 89 crx hf? what alse i need to buy? please help
Old Jan 16, 2009 | 11:51 AM
4drEF's Avatar
Keyboard Humorist
Default Re: 91 da gs to 89 crx hf
Engine mount swap kit, OBD-0 to OBD-1 conversion harness, and ECU (if you don't have that from your friends car).
Old Jan 16, 2009 | 11:54 AM
1stgenboost's Avatar
Rosetta stone for the english language would also help.
Old Jan 16, 2009 | 12:11 PM
crxhondata's Avatar
i have obd0 to 0bd1 conversion kit and yes the ecu will come with the car
i just need to buy crx b series motor mounts thats all?
Old Jan 16, 2009 | 12:22 PM
4drEF's Avatar
Keyboard Humorist
Forgot - shift linkage.
Other than that it seems that you have it covered.
Old Jan 16, 2009 | 12:55 PM
93formula's Avatar
90/91 is obd0, 92/93 is obd1 so unless you have the 92/93 ecu and the 92/93 dist you wont need the jumper. also the engine harness is not plug and play you use your harness and modify it for mpfi by using the da engine harness.
Old Jan 16, 2009 | 02:46 PM
crxhondata's Avatar
yeah i know i need to cut the shift linkage to fit thanks for your help
Old Jan 16, 2009 | 02:47 PM
crxhondata's Avatar
i guy is going to convert the engine harness for 30$ thanks
Old Jan 16, 2009 | 03:15 PM
ef_junky's Avatar
isn't an hf already mpfi? jus an 8 valve very restrictive intake manifold and stuff or small......
Old Jan 16, 2009 | 03:57 PM
crxhondata's Avatar
i dont know what mpfi means i pay someone to convert the engine harness
Old Jan 16, 2009 | 04:02 PM
specialized108's Avatar
.... priceless
Old Jan 17, 2009 | 05:00 AM
b18atcrx's Avatar
hf's and si's are mpfi (multi-point-fuel-injection) dx's are the only dpfi (dual-point-fuel-injection)
mpfi=4 injectors
dpfi=2 injectors
thus if you had a dx you'd have to wire it so the swap has the wires for the other two injectors needed for that motor. and a few other wiring changes. but since you have an hf you just need mounts and modified shift linkage. no wiring chages needed. and please learn to type and spell correct.
Old Jan 17, 2009 | 09:29 AM
ef_junky's Avatar
thats exactly what i was thinkin... i mean why would you have to convert the harness unless someone is tryin to rip ya off cause there both still obd0....
Old Jan 17, 2009 | 01:10 PM
wasabivtec's Avatar
perhaps hes not getting the engine harness and someone is extending wires for his hf one to work? All i can figure
Old Jan 17, 2009 | 08:00 PM
crxhondata's Avatar
thanks to all for all the help please DELETED this thread
Old Jan 17, 2009 | 08:10 PM
NFRap1's Avatar
lol...sorry
Old Jan 17, 2009 | 08:35 PM
90crxdxY8's Avatar
i feel stupider just for attempting to read his ethug slang jibberish
Old Jan 17, 2009 | 08:51 PM
Jonknee's Avatar
Way to go alabama!
THEhomelessONE
Dec 25, 2018 08:39 PM
Luward
Aug 6, 2013 03:37 PM
ph3ar
12
Oct 30, 2007 09:17 PM
93civiceg6
May 30, 2006 11:40 PM
