blox tps question
Old Jan 15, 2009 | 08:59 PM
wicked krx's Avatar
Default blox tps question
I have a 02 rsx type s and I just installed the blox tps it didnt come with any instructions so i just installed it and calibrated it to .45volts. my vtec works good on first and second but on third gears it does like a little pause and then the vtec activates. and after a while my vtec doesnt activate and at six thousand rpms my car just tops off and like if it was redlining. any help and also my check engine light is on and blinks sometimes. I also put a scanner on my car and got code p1166. I also replaced the a/f sensor that is like and 02 sensor so anybody please help. thanks.
Old Jan 16, 2009 | 06:29 AM
Type-Spaz's Avatar
DC5/EP3 MOD :)
Default Re: blox tps question
why did you buy a blox tps sensor?
Old Jan 16, 2009 | 10:30 AM
wicked krx's Avatar
i bought it because my tps went bad and i went to acura and it cost 700 dollars so i bought the blox tps
Old Jan 16, 2009 | 10:42 AM
h8ted ek's Avatar
daym dude, you should try the hybrid/swap part of this forum, i think thats wat it is. im pretty sure they have it covered. or go on K20a.org
seemed like you did everything right, havin it calibrated, iwouldnt no why it would do the other things you mentioned, try rechecking and do some search on other sites
Old Jan 16, 2009 | 11:24 AM
wicked krx's Avatar
i tried everything and nothing and im going nuts already
Old Jan 16, 2009 | 12:45 PM
Type-Spaz's Avatar
DC5/EP3 MOD :)
p1166 code? The primary o2 heater circuit code? You check into a new o2? Or check for a heater fuse? not sure if our cars has one, my accord did.
eM1<3
10
Apr 2, 2009 09:34 PM
b16a3delsol
May 21, 2007 12:16 PM
TheIceMan
12
Dec 23, 2005 04:08 AM
crxhfpower123
Mar 22, 2003 08:02 PM
