FS: F20c ae86 racecar/trackcar/DRIFTO!!
JDM! RHD!!!! 1985 ae85 Toyota Levin Facelift
UNder the hood:
* JDM!!! Honda s2000 F20c 2.0l 250hp (184 kW)
*Torque 153 lbft (207 Nm) @ 7500 rpm
*Redline 8800 rpm
*Bore & Stroke 87.0mm(3.4 in) x 84.4mm(3.3 in)
*Compression Ratio -11.1:1
*Valvetrain 16-valve DOHC VTEC
*Transmission -6-speed manual
*Displacement -1997 cc (121.8 cu in)
*The F20C produces the highest specific power for any naturally aspirated piston engine in a car worth less than US$100,000
* Custom built stainless Extractors with 2.5" mandrel bent exhaust under diff one resonator
* kakimoto 2.5 stainless muffler
* Exedy Hyper Clutch kit + flywheel
* Standard Coil on plug igntion
* Standard Intake Manifold
* EGR system blocked off (stainless plate)
* Evap Canistor system ditched
*450hp walbro external fuel pump with surge tank
*Braided hose from pump to rail
* Ford Cortina Engine mounts
* Custom crossmember to accomadate F20c
* Custom gearbox crossmember, s2000 gearbox mounts
* AC ditched
*Custom 3" single peice driveshaft and safety hoop
*Custom gearbox tunnel
*Alloy intake and pod filter
*Rx7 alloy radiator Core Size : 313x618x52mm, added filler neck
*Stainless radiator pipes and silicon joiners
*Alloy radiator support beam
*Custom stainless Radiator support brackets
*2x slim line fans, switch activated
*Genuine Cusco Strut brace
*Mugen Oil Filter
*J's Racing Filter stoper
*J's Racing Hood pins
*Corona 1" Brake Master cylander and booster
*Custom Throttle cable
*Brand New o2 sensor
*Engine bay seam welded
*LSD Hilux Diff 4.3 : 1 reshimmed, new oil
*deloomed and tucked
Brakes/Suspension
*260mm 2piece vented rotors and 4pot lockheed calipers, re sealed and kitted, with new nipples as well
*Pagid Blue Brake Pads
*Nissan Primera Rear Discs brake conversion, new mintex pads
*Whiteline front and rear swaybars
*Whiteline Adjustable Panhard Rod
*Adjustable, rose jointed radius arms(castor arms)
*New Honda Odyssey Nolathane swaybar bushes and Oddysey swaybar link arms
*AE92 Front struts converted to coil-over, with 8.8kg/mm rated springs
* TRD tokiko adjustable front shocks , hilux 4x4 shocks in rear
*Rear springs TRD 6 kg/mm rated springs
*Adjustable front camber plates
*TC Sportline Rear traction brackets
*Nolathane bushes all round
Wheels
*15 X 8 sportmaxx 02 wheels zero offset 4x114.3 + 4x100
*15 x 7 work equip copys 15p wrapped in toyo R888s
Interior
*HKB Toyota Boss Kit
*Nardi Plate adapter
*Genuine Nardi deep dish steering wheel 300mm leather, red stitching (weaksauceparts.org)
*Skunk2 Gen 2, 10th edition Gear ****
*S2000 Cluster, in perfect working condition, lights, hazzards, brake fluid warning light, hand brake warning light, high beam, indicators, speedo, tacho, odo, fuel light, water temp, oil pres, fuel gauge
*killswitch (poor mans alarm)
*Autosport Carbon/kevlar seat, very light
*momo fibreglass bucket seat
*fire exstinguisher(sp)
*6 Point MANZ approved roll cage with log book. + added harness bar
*Padded around head area
*Sound deadening has been removed
*Buddyclub drycell battery
*rear boot shocks regassed
Exterior
*Full copy Origin body kit sideskirts and rear, Dmax front bumper (have old origin front, but a bit damamged) dmax (heavily repaird with poor mans race tape)
*Trueno Facelift rear tailights
*Zenki front grille
*100watt super white light bulbs
*$1200 worth of rust repair/removal and body work done
*Ford Falcon/territory paint (not the best)
truely a turn key ready to go racecar, have daily drivin this all winter no problems! (besides no heater :-P)
has ran 12.8 @ 171kph on 205/50/15 circuit tyres
based in New Zealand ( lord of the rings, frodo)
got a quote to ship to Los Angeles California.
20' own container
USD 3165
40' shared container (ie have to find another car that is being shipped and share 1 container)
USD 1800
POA!
Build thread = https://honda-tech.com/forums/showth...ight=f20c+ae86
UNder the hood:
*Redline 8800 rpm
* AC ditched
*Mugen Oil Filter
Brakes/Suspension
Wheels
Interior
Exterior
*Zenki front grille
20' own container
USD 3165
USD 1800
POA!
Frodo has no license and he cant reach the pedals but if he could he would want to drive this car for sure. Would have made the whole trip to mordor a lot quicker, probably would have tied the whole trilogy up in a bout 15 mins and saved everyone the 9 hours of pain.
Good luck Ian.
Good luck Ian.
